996 : 1997-2005 29
Boxster : 1997- 14
DJP997
PostPosted: Sat Oct 06, 2018 6:27 am    Post subject: 997 Gen 2 PCM 2009 - Music Stream Reply with quote
Good morning,
I have this week swapped my Gen1 turbo for a Gen2 and have a query on the PCM which i'm hoping someone can help with.
I've been able to sync the PCM with my phone for calls, etc.
I would like to stream music from deezer on my iphone 5s. Could anyone kindly confirm if this lightning connector is the only thing i need to get this working ??
https://www.ebay.co.uk/itm/291503683589
Thanks!
slackster
PostPosted: Sat Oct 06, 2018 9:52 am    Post subject: Reply with quote
Best option I’ve found is the bovee 1000 bluetooth dongle.
Plug that straight into the PCM3 ipod cable and pair your phone up that way.
I only stream my itunes or podcasts to it but I assume deezer will work the same Thumb
BTW, I bought one of those lightning convertors also and whilst it does work the connect the phone, I couldnt fit that and the phone under the armrest lid properly so went for the bovee Smile
Gen I | 997 TT | Basalt Black
Gen I | 997 c2s | Atlas grey
Gen I | 987 cayman S | Atlas grey
c4kum
PostPosted: Sat Oct 06, 2018 12:11 pm    Post subject: Reply with quote
^ That ^
DJP997
PostPosted: Sat Oct 06, 2018 12:32 pm    Post subject: Reply with quote
Thank you very much chaps thumbsup
Glad i asked now!
PostPosted: Sat Oct 06, 2018 12:35 pm    Post subject: Reply with quote
Make sure you have the porsche Y cable if not its under £30 from the OPC then as the others have said connect the Y cable to a bovee1000 and you will be good to go with bluetooth streaming music from your phone to the PCM Thumb Thumb
Gizmo750
PostPosted: Sat Oct 06, 2018 3:54 pm    Post subject: Reply with quote
I just bought a cable / adaptor from Apple to stream Spotify from my iPhone so if you have the audio interface I can't see why you would need more than that. It's essentially the same as the adaptor you've linked to but it has a cable "middle" part which allows it to fit in the arm rest
Part code is MD824ZM/A
997.2 C2
848 (also rear wheel drive)
systech1
PostPosted: Sun Oct 07, 2018 9:43 am    Post subject: Reply with quote
IIRC the iPod connector on the Audio interface in the 997.2 does NOT provide the correct number DC (5V?) power for the iPod ( or Bovee Bluetooth adaptor or whatever) which is why you need the Porsche Y cable. The USB part of the adapter cable provides the DC. I use a small 2 port USB adaptor and use one port for a USB stick for a heap of songs
Long time Porsche fan. Previous cars include 911T 2.2, 911E 2.2, Carrera 3.0, 986 Boxster S. Current car is 997.2S Manual (with PSE, H&S Backbox bypass, Sports Chrono, SSK, Carrera Sports wheels, Sport Design steering wheel etc.)
DJP997
PostPosted: Sun Oct 07, 2018 1:26 pm    Post subject: Reply with quote
Firstly, thanks to all for taking the time to help me out.
Unfortunately, I am less clear on what is needed than at the start Laughing
Here is a pic of all that I have currently.... could anyone confirm please what i need to be able to stream music from my Iphone 6s ?
Is what I have plugged in, the 'Y cable' ??
c4kum
PostPosted: Sun Oct 07, 2018 3:26 pm    Post subject: Reply with quote
Ok, you seem to already have the y cable, the usb cable on the Y cable needs to be plugged into the usb socket, all you then need is a Bovee 1000 30pin device, that’s is and stream until your heart is content.
DJP997
PostPosted: Sun Oct 07, 2018 5:30 pm    Post subject: Reply with quote
OK - so with what i have, Bovee will do the job.
Do you know if this Apple lightning cable/connector will also do the same job as the Bovee ?
https://www.uk.insight.com/en-gb/productinfo/notebook-and-handheld-accessories/0001444886
PostPosted: Sun Oct 07, 2018 5:37 pm    Post subject: Reply with quote
Yeah Yeah Yeah Agree Thumb stream bluetooth , theres other ways to do it that will mean pluging the phone in every time for a hard wire link, but the Bovee is a tested way to bluetooth. Theres also an option from Visio as I am sure there will be others but we know the Bovee works and also interfaces giving you album title etc on the PCM which other options may not do. Thumb
DJP997
PostPosted: Sun Oct 07, 2018 5:45 pm    Post subject: Reply with quote
Thanks Phil / C4kum
thumbsup
I will order the Bovee since it's tried & tested.
mkoenigsheim
PostPosted: Sun Oct 07, 2018 6:21 pm    Post subject: Reply with quote
Get the Bovee.as the rest of the guys say say - if not you need to plug the phone in and put it somewhere - if the lightning cable/adaptor works - don't know anybody using it.
The y cable is needed so you connect the usb part to the car usb- Apple changed the power connections and this workaround was needed to power any device.
With the Bovee I haven't had an issue in 2 years... When an iPhone is connected you get full menu access as if it was directly connected- great bit of kit.
Myasinax
PostPosted: Sun Oct 07, 2018 6:31 pm    Post subject: Reply with quote
Hi mate
Can you elaborate on the 2 port splitter, I want to keep the iPhone charged (USB to lightning cable) and also what format do you have the USB stick in to read music to the PCM3 module? FAT32?
James M-S
2009 Porsche 997 Carrera 2
PostPosted: Sun Oct 07, 2018 7:21 pm    Post subject: Reply with quote
I have the Apple 30pin to lightening cable, it does charge the phone when used with the y-cable. (You have to have phone on passenger seat)
I don’t use it though.
My set-up is:
y-cable attached to bovee
USB splitter plugged into USB port in armrest.
USB end of y-cable plugged into one of the ports of the USB splitter. (To power the bovee)
USB thumb drive full of music plugged into the other port of the USB splitter.
I can stream to bovee using iPod or aux as the source.
Waze audio alerts come over the music (music vol just reduces slightly)
I use yosh magnetic air vent clips (2) to hold my iPhone as I use Waze for satnav. (£8 from amazon, bargain)
The only downside is I need a cable going up to the air vents to charge the phone if I’m using the nav for long periods. (Currently use cig lighter charger) Improvement would be a 3-way USB splitter in and run a concealed longer lightening cable up to the vents somehow.
I can’t get tracklisting displayed on my PCM when using bovee or Apple cable, think that must be because I have the original pcm software version.
Hope that helps.
systech1
PostPosted: Mon Oct 08, 2018 12:58 am    Post subject: Reply with quote
Hi mate
The 2 port USB hub I used appears to be no longer available so you will need to find a 2 port variant of something like this...https://www.ebay.com.au/itm/4-Port-USB-2-0-HUB-Compact-Slim-For-PC-Laptop-Mac-500mA-Output-Power-Plug-Play/201065398009?epid=17018679787&hash=item2ed06e7ef9:g:33QAAOxyCGNTO4J5
You need something with a cable to enable access to the USB port in the car.
FAT32 is fine. IIRC, the largest USB size you can use reliably is 16GB
James M-S
PostPosted: Mon Oct 08, 2018 6:43 am    Post subject: Reply with quote
I use a 64GB thumb drive in mine. Just takes a while to read all the tracks.
USB 2.0 Charging & Data Sync... https://www.amazon.co.uk/dp/B071H54CKS?ref=yo_pop_ma_swf
I use the above USB splitter cable
davenice
PostPosted: Tue Oct 09, 2018 7:56 am    Post subject: Reply with quote
I use a wired solution with my 6s+ consisting of the following:
Porsche Y cable.
APPLE Lightning to 30-pin Adapter £29. Only a genuine one made by Apple worked
Lighting extension cable,1metre. £7 (amazon)
Breffo Spiderpodium Flexible Grip/Mount Car Phone Holder. £15 (Amazon)
The mount goes into the vents. Pretty useful as I use the phone with Waze a lot.
This set up gives phone charging, track display on PCM, full control of all music/podcast apps that I have tried. The phone still connect to the PCM’s Bluetooth for calls etc.
My car is a 997.2 with the universal audio interface option.
davenice
PostPosted: Tue Oct 09, 2018 8:10 am    Post subject: Reply with quote
Does the PCM play all .mp3 files on your thumb drive? When I tried to use a 32Gb FAT formatted drive, I found that roughly half of my tracks got skipped over. Could have something to do with the encoding of the files but I couldn’t work out a pattern.
DJP997
PostPosted: Wed Oct 10, 2018 9:31 am    Post subject: Reply with quote
Received Bovee today, all works as suggested, thanks guys.
Do you leave the Bovee plugged in overnight etc? I assume it is not powered but wanted to check it doesn't cause any issues....
Goto page 1, 2, 3  Next
Page 1 of 3
