996 : 1997-2005 29
Boxster : 1997- 17
Cayman : 2005- 20
Gorsh
2015 Porsche Boxster 981
PostPosted: Fri Oct 05, 2018 10:03 am    Post subject: Reply with quote
Why has it blanked out flick with an ing on it?
981 Boxster GTS
991.2 Carrera GTS (sold)
MaxA
PostPosted: Fri Oct 05, 2018 11:05 am    Post subject: Reply with quote
I don't like leaving the car in auto to warm up: I feel that it's changing up far too early and lugging the engine when cold ... trying to pull sixth at 1000rpm is wince-inducing. I also feel like the gearbox is slipping the clutch too to soften the changes. Eew.
Since I'm happy to drive it in sport & manual, I can keep the revs between 2-3k rpm where I want them to be for the first 10-15 minutes or so. And in winter I use an engine block heater to pre-warm the block (coolant gets to around 35c or so) and speed up the process/reduce cold start wear.
I think it is important to get some heat into all of the engine, gearbox, tyres and brakes before driving hard.
2010 9972 C4S PDK: Carrara White, Sea Blue. Mostly driven, lightly modified, occasionally tracked, and usually a bit grubby.
Gorsh
PostPosted: Fri Oct 05, 2018 12:30 pm    Post subject: Reply with quote
I assume a block heater is the norm where you live, and necessary too, but I've never come across one in the UK (loads of you will now come forward to say you have them I bet!) the temperature is rarely more than a few degrees below freezing.
Agree about keeping the revs up a bit and engine loads light until warmed.
981 Boxster GTS
tim993
2016 Porsche Boxster 981
PostPosted: Fri Oct 05, 2018 12:57 pm    Post subject: Reply with quote
I'm afraid to say I tired of the PDK. Its too easy just to leave it in auto mode (as it's so good) and I'm afraid I didn't really like driving it as a manual, as it felt a bit contrived. Its a very personal thing I know. So, I've gone to a manual car now and I'm soooo much happier. It would be a very different story if my car was a daily driver, I'm sure. I suppose I never could get the feel of driving a 993 out of my head, so craved the engagement you get with a manual 'box, but in a more modern machine.
"I don't know what it is about peace conferences, but they always seem to attract terrorists, extremists and nutterists."
1995 993 turbo
Goto page Previous  1, 2
Page 2 of 2
