997 : 2004- 77
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 12
steve1
2002 Porsche 996 Carrera 2
PostPosted: Fri Sep 14, 2018 11:48 am    Post subject: small black front wheel arch fittings. Reply with quote
Hi guys
Any body know how to remove the small black front wheel arch fittings.
Thanks in advance
2002 996 C2 cab red
maldren
PostPosted: Fri Sep 14, 2018 1:00 pm    Post subject: Reply with quote
IIRC there are two types of black fixings, nuts screwed onto studs and push pin studs which have a pin pushed into a clip.
For the former, unscrew. For the latter, use a fine flat blade screwdriver to lever out the central plastic part leaving the outer plastic clip in place, then pull out the outer part.
Mike
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Fri Sep 14, 2018 2:12 pm    Post subject: Reply with quote
Ideally you need a flat, pronged trim remover tool.
PostPosted: Fri Sep 14, 2018 6:49 pm    Post subject: Reply with quote
This set pretty much covers any work you will do on your car were trim tools are needed .
several there will remove the plastic arch clips .
https://www.ebay.co.uk/itm/5pc-Plastic-Metal-Trim-Car-Panel-Removal-Tools-And-Pliers-Non-Scratch-/400977596977
steve1
PostPosted: Fri Sep 14, 2018 7:22 pm    Post subject: Reply with quote
Thanks guys
2002 996 C2 cab red
wasz
1999 Porsche 996 Carrera 2
PostPosted: Sat Sep 15, 2018 3:29 pm    Post subject: Reply with quote
You just swear at them really loudly, then bosh them with a sharp chisel and go to the OPC for some more.
Guywilko
PostPosted: Sun Sep 16, 2018 6:07 am    Post subject: Reply with quote
replacement clips are cheap as chips on ebay. Search as a vw part.
steve1
PostPosted: Tue Sep 18, 2018 9:49 am    Post subject: Reply with quote
Yep that works new ones on way.
2002 996 C2 cab red
