997 : 2004- 77
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 12
AlanPM
2003 Porsche 996 Carrera 4S
PostPosted: Wed Sep 12, 2018 6:06 pm    Post subject: Engine check light issue Reply with quote
Hi guys. I keep getting a misfire on cylinder 2 code once up to temp and on Ritick over, clears with revs but just noticeable as lumpy at low revs. Changed all coil packs and plugs. What’s next to try?. Thanks in anticipation.
2003 911 C4S cabriolet, manual,
Polar Silver with Metropol Blue interior, LTT, SSK, wheel spacers, Design Tech CAI, BMC Sports filter, Remap, RS engine mounts.
2007 BMW 335i M Sport
911UK
Porsche Community
Porsche Community
1997 Porsche 993 Carrera 2
PostPosted: Wed Sep 12, 2018 6:29 pm    Post subject: Reply with quote
have you had checked with a PIWIS tester ?
Get a Porsche Car Insurance Quote
FOLLOW 911UK ON FACEBOOK
PostPosted: Wed Sep 12, 2018 7:52 pm    Post subject: Reply with quote
If you know its cyl no.2 then i assume you are getting a fault code for that cylinder and nothing else basically saying misfire .
3 things can cause a SINGLE cyl misfire ..
No or a weak spark .
No or a low compression , valves , rings worn .
No or a poor injector spray pattern .
Actually 4 things .. inlet mainifold seal on that cyl is leaking .. so rare as to be almost impossible .. but .. erm .. its possible .. just .
Swop the injector with another and see if the fault switches cyl to the one you have swopped it with .
Do a compression check .
If the above is ok then you need to pin out the wireing from injector / coil to the dme and check for continuity .
if thats ok you are left with a faulty dme which would be pretty dam rare .
AlanPM
PostPosted: Thu Sep 13, 2018 8:00 pm    Post subject: Reply with quote
Thanks deMort, will get it to the local indie ASAP me thinks thumbsup
