964 : 1989-1993 6
Boxster : 1997- 17
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
MJA911
2012 Porsche 991 Carrera
PostPosted: Tue Sep 11, 2018 7:58 pm    Post subject: Bass vibration from drivers door BOSE speaker Reply with quote
My drivers door Bose speaker is vibrating with relatively low volume bass, quite annoying, but before I take a look and try to fix it, I was wondering if anybody else has had this problem and solved it. Thanks for any advise.
991.1 C2, 986 Boxster S
Past pleasures: 997.1 GT3, 997.2 C4S Cab, 993 C2, 997.1 C2S, 996.1 C4
blackram
PostPosted: Tue Sep 11, 2018 8:49 pm    Post subject: Reply with quote
I have the same which I thought was the Bose speaker in the driver’s door but turned out to be the window/mirror switch set panel which buzzes. Try pressing it and see if it stops the buzzing. The OPC said that it is not covered under the Porsche extended warranty so putting up with it for the time being (it is intermittent fortunately).
991.1 Carrera S Agate Grey
MJA911
PostPosted: Tue Sep 11, 2018 8:53 pm    Post subject: Reply with quote
Ah, ok, I’ll check that out. Mine is under warranty too, sounds like that would be a waste of time then.
blackram
PostPosted: Thu Sep 13, 2018 8:12 pm    Post subject: Reply with quote
Please check with OPC first though, just in case. If they say yes please let me know!!
MJA911
PostPosted: Thu Sep 13, 2018 8:48 pm    Post subject: Reply with quote
Used car today and tested the switch theory and sure enough that’s where the vibration/buzz is coming from, pressing on the edge of the switch assembly stops it. Doubt very much it’s a warranty job, my plan is to see if I can stop it somehow. Thinking of finding out how the switch can be removed and then reseating it with plumbers tape so that it’s a tighter fit Dont know
ragpicker
Estoril
PostPosted: Fri Sep 14, 2018 6:46 am    Post subject: Reply with quote
I thought Porsche got all the rattles out of their system with the 996!
PC
MJA911
PostPosted: Fri Sep 14, 2018 6:57 am    Post subject: Reply with quote
Haha, don’t think so, all my 997s had a rattle or two, mostly solvable (or went away) though, OPC injected the instrument binacle with foam on my 997.2! This windows/mirrors switch assembly buzzing on the 991 seems inevitable, it’s mounted directly above where a speaker is housed.
New997buyer
PostPosted: Fri Sep 14, 2018 8:40 pm    Post subject: Reply with quote
Dont know
“Try not to become a man of success. Rather become a man of value.” Albert Einstein
Present - 997.1 turbo man
Past - 997.1 turbo tip S, 996.2 turbo tip S, 996.1 C2 man
blackram
PostPosted: Sat Sep 15, 2018 4:23 pm    Post subject: Reply with quote
This is an extract from Rennlist.com.......
”I’ve replaced both driver and passenger window switch units... it requires door card removal, which isn’t that bad, but if you have plastic doors instead of leather, getting in there will irritate the door enough the trim will start to bend and come up, and you’ll end up needing all new door cards which are like $3k.
So have the dealership do it so when the door cards bend up, you can make them replace those for free.”
So tread carefully although I think you may be able to release the switch panel from the door card with out removing the whole card and re-set them with some sort of sealant. Please let us know how you get on...
MJA911
PostPosted: Sat Sep 15, 2018 4:38 pm    Post subject: Reply with quote
Yes I saw that post but didn’t want to tackle door card removal Surprised
Today I very gently tried using a plastic spatula to see of the switch would come out enough so that I could pad it with loom tape and replace, but it wasn’t playing ball and I didnt want to push my luck. Instead I used the spatula to create enough clearance around the sides of the switch to push a couple of pieces of sticky padded tape into the gap each side. It seems to have improved it, but I’d say doing it properly needs the switch out.
ragpicker
Estoril
PostPosted: Sat Sep 15, 2018 5:31 pm    Post subject: Reply with quote
@mja911 I imagine you are like a brain surgeon when using trim spatulas..
