964 : 1989-1993 5
Boxster : 1997- 18
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
½cwt
PostPosted: Fri Sep 07, 2018 3:52 pm    Post subject: 3 Flash Indicators Reply with quote
OK, so I've got my new (old W plate) Boxster S. Is there a kit to give 3 flashes on the indicator. Going back 18 years in history is mighty frustrating as I have this feature on all my cars since 2006 and that was a W plate A6!
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Fri Sep 07, 2018 10:47 pm    Post subject: Reply with quote
There was a thread about this recently which you may find if you use the search function.
½cwt
PostPosted: Sun Sep 09, 2018 3:59 pm    Post subject: Reply with quote
Had a good search through using various key words, can't find the tread or at least can't see it. Anyone know where it might be?
PostPosted: Sun Sep 09, 2018 8:23 pm    Post subject: Reply with quote
have a read of this I am sure it will point you in the right direction
https://e31wiki.org/wiki/One-touch_turn_signal_module
ian_alex
PostPosted: Sun Sep 09, 2018 10:00 pm    Post subject: Reply with quote
There s a fairly simple way to do this using a VW relay kit. I did it last year and it works perfectly.It involves removing the instrument binnacle and wiring in the new relay.
There is a guide on here somewhere, when I get home I will try to dig out some more info and post it, in the meantime keep searching!
pzero
PostPosted: Mon Sep 10, 2018 5:45 am    Post subject: Reply with quote
http://911uk.com/viewtopic.php?t=124611&postdays=0&postorder=asc&start=0
ian_alex
PostPosted: Tue Sep 11, 2018 9:43 pm    Post subject: Reply with quote
This is the guide I used and it works. A good mod. In my view and inexpensive!
