996ttalot said:More frequent fluid changes will help for sure.
There have been failures and since there is no serviceable parts in the box Porsche only solution is to offer replacement PDK transmission.
After investment and research, we will be able in the near future offer full repairs on these boxes and enable them to be serviceable. We will make an official announcement on that in due course. Clearly there will be a big market for this in the future, hence why we have been working on a cost effective solution.
Ken
easternjets said:One of the things with the PDK box that came up in a conversation recently was the changing of fluids. One of the members on here had his PDK oil changed and sent the old fluid away for analysis, it came back as being well out of spec, so it would appear that like all mechanical items regular servicing is key to longevity.
I really can't fault my box in any way, it was such a leap forward over the old auto tip box that you can't even compare the two. Saying that the tip boxes are a very solid reliable item and I've heard that people have run them at up to a 1000 bhp with no problems.
doulas bader said:easternjets said:One of the things with the PDK box that came up in a conversation recently was the changing of fluids. One of the members on here had his PDK oil changed and sent the old fluid away for analysis, it came back as being well out of spec, so it would appear that like all mechanical items regular servicing is key to longevity.
Sent the old fluid away for analysis?? Hell fire, is this a car we are talking about ??
Whilst I am on replacing fluids regularly (before they are due) - how can this be a benefit? Surely the action of actually changing the fluid carries more risk than the not-ready-for-disposal fluid offers to the mechanics??
Counter Of Beans said:Question: when we talk about replacing the fluid, are we referring to the clutch fluid (Porsche say every 6 years on my 2011 car) which is some sort of ATF?
Or are we referring to the 12-yearly gearbox fluid change which I believe is just normal 75W-90 gear oil?
easternjets said:doulas bader said:easternjets said:One of the things with the PDK box that came up in a conversation recently was the changing of fluids. One of the members on here had his PDK oil changed and sent the old fluid away for analysis, it came back as being well out of spec, so it would appear that like all mechanical items regular servicing is key to longevity.
I would comment on your reply if I understood what you were talking about, it makes no sense. Are you advocating NOT changing the fluids as they are a risk to the mechanics? Are you saying that if you have a fault in a gearbox, that you would NOT have the fluid tested to see if it was the root cause of a problem, instead you would have the gearbox replaced maybe?
