997 : 2004- 64
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 10
Cayenne : 2003- 4
Macan : 2014- 1
gtb5
PostPosted: Thu Sep 06, 2018 5:28 am    Post subject: Unbalanced Exhaust Tips Reply with quote
Just noticed the right tip is protruted more than left side and there are no signs of damage on the tips upon close inspection so might be a factory defect. Wondering how much work needs to be done at the dealer to correct this and anyone has similar condition.
 Filesize:  98.81 KB
 Viewed:  1564 Time(s)
PostPosted: Thu Sep 06, 2018 8:31 am    Post subject: Reply with quote
Looks a bit 'tipsy' to me Drinkers
schater
Tumble Weed
MJA911
2012 Porsche 991 Carrera
PostPosted: Thu Sep 06, 2018 8:57 am    Post subject: Reply with quote
The tips are attached to the pipes via a relatively simple collar, should be pretty straightforward to unclamp the right tip and see if it isn't pushed onto the pipe quite as far as the left. If it is, then the misalignment must be coming from somewhere else on the exhaust or engine mounting.
991.1 C2, 986 Boxster S
Past pleasures: 997.1 GT3, 997.2 C4S Cab, 993 C2, 997.1 C2S, 996.1 C4
coullstar
Tips are probably just trim so can be adjusted fairly easily.
FZP
Paul Ricard
PostPosted: Thu Sep 06, 2018 10:55 am    Post subject: Reply with quote
In theory it's a 2 min job. In reality it will require so many tools and wd40, heat and God knows what else to shift them. My experience with exhaust says so. I hope it's the first for your sake.
gtb5
PostPosted: Fri Sep 07, 2018 3:01 am    Post subject: Reply with quote
Looks like my car's really a Friday production, not only they installed 718 shifter but this also. See what they say early next year when I go for service.
