997 : 2004- 71
964 : 1989-1993 5
Boxster : 1997- 21
Cayenne : 2003- 4
decgraham
PostPosted: Tue Nov 27, 2018 11:18 am    Post subject: Reply with quote
The oil on the dipstick is always clean, it goes into the tank in the rear RHS wing space. This is why it is difficult to see it on the dipstick. The best way I've found is to bring the car up to temperature, if you watch the oil temperature gauge you will see it rise to the 8 O'Clock mark just go above it and then drop back. This tells you that the thermostat has opened, it usually takes about 8 - 10 miles of driving. Once you've got the thermostat open and the car nice and warm get it on a level surface with the engine running and remove the dipstick. Clean the dipstick with a piece of kitchen roll. Re-insert the stick and then withdraw it and place it on anther piece of clean kitchen roll with the end of the stick at the edge of the kitchen roll. The oil should leave a clear oil mark on the kitchen roll which if you've got it right should be just short of the second twist. As said, the gauge inside the car is not accurate.
Here's a YouTube video you might find useful, not Porsche but you'll get the idea.
https://www.youtube.com/watch?v=UMKeFspGKbk
ATB Smile
Goto page Previous  1, 2
Page 2 of 2
