Boxster : 1997- 20
Jonnywise
PostPosted: Wed Aug 29, 2018 7:44 pm    Post subject: Another bad experience at a Indy Reply with quote
Took my car to have is major service done and water pump replaced at a recommended Indy near me,picked my car up today and 2 miles down the road warning light comes on check coolant level we can all guest what they have not check themselves Question
It must be me and Indy's don't mix Mad
PostPosted: Wed Aug 29, 2018 7:54 pm    Post subject: Reply with quote
Its not uncommon to get an airlock in the pipe after changing the pump but having said that I would have expected them to have known that and rechecked the levels several times.
MJA911
2012 Porsche 991 Carrera
PostPosted: Wed Aug 29, 2018 8:50 pm    Post subject: Reply with quote
Isn’t it the case that an airlock could have been released during your drive to cause that? I remember when the water pump was replaced on a previous car, garage said to check the levels after a drive or two for that reason.
991.1 C2, 986 Boxster S
Past pleasures: 997.1 GT3, 997.2 C4S Cab, 993 C2, 997.1 C2S, 996.1 C4
911UK
Porsche Community
Porsche Community
1997 Porsche 993 Carrera 2
PostPosted: Wed Aug 29, 2018 9:36 pm    Post subject: Re: Another bad experience at a Indy Reply with quote
who was this Indy ?
and are they fixing this ?
Get a Porsche Car Insurance Quote
FOLLOW 911UK ON TWITTER
Jonnywise
PostPosted: Wed Aug 29, 2018 10:24 pm    Post subject: Indy Reply with quote
Dint really wanted to name and shame them
They were closing when I was leaving so,I will contact
Them in the morning.no advice given on checking levels
After a few miles,I would of thought they would say
Bring it back and we will top it up ,but I don’t want
To drive it with the warning light on and if it’s not a
Air block it could be a leak
Jonny
kurlykris
PostPosted: Wed Aug 29, 2018 11:14 pm    Post subject: Reply with quote
Given that water cooled 911s are notoriously difficult to bleed after work on the cooling system, I would give them the benefit of the doubt on this one as long as it didn`t overheat ?
Let them sort it out, everyone makes mistakes afterall Question
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
Jay.
PostPosted: Thu Aug 30, 2018 12:30 am    Post subject: Reply with quote
Hopefully just an air lock. They should have taken it for a quick test drive to make sure this didn't happen to you though
2004 996 Turbo
Seal Grey
Motec 19" Alloys
AMG Flappy Paddles
1972 Datsun 240z
RB25DET
Devil Z
Follow me on Instagram! @rb.240z
toddy2
PostPosted: Thu Aug 30, 2018 4:38 am    Post subject: Reply with quote
I had the same issue when I had my water pump replaced. It needed topping up by a litre seems fine now.
Current Porsche Line up:
1968 911T
2002 996 4s
1988 944 (Sold)
MaxA
PostPosted: Thu Aug 30, 2018 8:05 am    Post subject: Reply with quote
After I had my coolant flush, I was told that airlocks were likely, and that I should keep an eye on it. It took some time, but I ended up adding a full litre of coolant to reach the right level on the expansion tank. I would have been concerned if a light popped up: suggest you simply take it back for a top up.
PostPosted: Thu Aug 30, 2018 8:09 am    Post subject: Reply with quote
Not being funny but air locks when doing any work on the cooling system are the most common thing ever. For an Indy not to have sorted this is pretty lame.
I would at least expect them to make you aware of air locks, give you a container full of coolant and ask you to check and top up repeatedly over the next few days until it settles.
Bad Practice!
Jonnywise
PostPosted: Thu Aug 30, 2018 11:37 am    Post subject: Indy Reply with quote
Here was There replie
Dear Jonny,
I did have the technician check a few times before you collected however sometimes the car does hold an air bubble unless it gets to certain temperatures. Apologies for the inconvenience caused. We added enough coolant so the water won’t affect the coolant/water ratio.
Please let me know if you have anymore trouble and I will get it sorted
Kindest regards
PostPosted: Thu Aug 30, 2018 11:40 am    Post subject: Reply with quote
Should've told you that when you collected the car.
PostPosted: Thu Aug 30, 2018 11:41 am    Post subject: Reply with quote
Did he tell you what to top it up with, tap water, distilled water, deionised water?
Jonnywise
PostPosted: Thu Aug 30, 2018 11:56 am    Post subject: Indy Reply with quote
No Alex,they did not mention anything,when I picked
It up just asked for my credit card
Jonny
toptime
PostPosted: Thu Aug 30, 2018 11:57 am    Post subject: Reply with quote
I replaced my water pump last week and it took a good few days and 50 or so miles until the water level settled.
Don't forget to check your bleed valve is shut once you are happy all the air has been released.
911UK
Porsche Community
Porsche Community
PostPosted: Thu Aug 30, 2018 12:30 pm    Post subject: Reply with quote
that and what MaxA said, it usually later
but straight out of the door is poor service when they claim to have checked it a few times, which is highly unlikely wack
MarkGolf
PostPosted: Thu Aug 30, 2018 12:41 pm    Post subject: Reply with quote
Interested to know what Indie this was, looks like you live where I do..
Current fleet
1991 964 Carrera
2005 997 Carrera S
2008 957 Cayenne GTS
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
1995 VW Golf VR6 3.0
Callughan911
PostPosted: Thu Aug 30, 2018 1:54 pm    Post subject: Reply with quote
Is this something you could have checked upon collection or would the tank have been full when you departed?
All garages without question, have good and bad reports.
PostPosted: Thu Aug 30, 2018 2:11 pm    Post subject: Reply with quote
You don't find out until the engine has been running and the air bubble pumped back round to the expansion tank........but this is a very simple common problem and the fact it wasn't sorted is pretty poor. Especially when the garage told him about it once he quizzed them after the event. Its as bad as not tightening wheel bolts up.
Jonnywise
PostPosted: Thu Aug 30, 2018 8:38 pm    Post subject: Indy Reply with quote
My local garage ended up putting 2 litres of coolant in.
As this was a recommendation,I Fill really let down by the Indy and by there response.i thought worst ways they would offered to pay for the coolant
Jonny
