Hi All,
New member here with my 1st problem with a 1998 C2
Engine was running a bit lumpy any my generic code reader indicates Bank 2 Oxygen sensor is open loop. Ordered a new pre-cat sensor but when I've come to replace it the old sensor nut is 21mm (same both sides)
My sensor socket is standard 22mm so don't want to use that and using an open ended 21mm spanner is a non-starter. Did some googling but I don't see any 21mm Sensor sockets available ???.
All write ups on this refer to 22mm sensors so not sure if I've got something non-standard on the car. Anyone had similar problem??
