997 : 2004- 74
Boxster : 1997- 14
NinjaPower
PostPosted: Mon Aug 20, 2018 10:39 am    Post subject: Buying 2008 Cayenne V8 4.8S - Good engine? Any problems? Reply with quote
Hi all,
Wanting a 2008 onwards Cayenne and going to look at one tomorrow night.
It's a 2008 4.8 and done 65k miles with full porsche history.
But... I've just been reading some horror stories about he V8 Cayenne engine. Apparently they suffer bore score?
But some are saying it's only the earlier 4.5 from pre-2007 that has issues.
Can anyone give me any information in this please.
Anything else to look out for?
Thanks!
993 C2
912 fully restored
Cayenne 4.8S
shalz
PostPosted: Thu Sep 06, 2018 9:49 pm    Post subject: Reply with quote
Sorry, Don't have anything helpful to add but following as I may go down this route too.
How did your viewing go?
'09 Cayenne D, Seal Grey
Cy00
PostPosted: Tue Sep 11, 2018 7:53 am    Post subject: Reply with quote
i have the same model year gts which is more or less the same engine with a slightly different intake and exhaust i believe.
its at 80k miles and well taken care of. It did come with its share of problems at around the 9yr mark.
Front control arm bushings, the cardan shaft, front stabilizer bar bushing,
front stabilizer bar endlinks all had to be changed. These were relatively simple jobs.
The more complicated labor intensive ones were the rear main crank seal and the torque converter seal for which engine and tranny had to be dropped. While doing that noticed the oil cooler o rings were leaking as well as the power steering pump. Porsche (or aftermarket) does not sell any o rings or gaskets for the power steering pump so i resued the power steering pump o ring with some high temp sealant and hope it holds.
Another expense in recent time was the ECU deciding to die on me. Replacement ecu from porsche is in the 7k gbp range. I managed to get a used ecu off ebay and clone the data from original one to the used one for about 1/3rd the price.
The ecu issue seems to be very rare and my case was probably a one off thing.
Also note various servo motors in the ac system may decide to die randomly based on age. The rear camera is also very temperamental and likes to get stuck in closed or open position.
Other things to check before purchase
subframe bushings, engine mounts. air suspension issues (if equipped), alternator, water pump condition.
911UK
Porsche Community
Porsche Community
1997 Porsche 993 Carrera 2
PostPosted: Tue Sep 11, 2018 10:11 pm    Post subject: Reply with quote
stick to the 957 gen post 2007 cars
these are much more reliable, age issues starting to have an impact
to add fro what Cy00 has said
- drive shafts need checking
- car's spec is important, IMHO Air suspension is a must
- price, dont pay over the odds for a low mileage car
Get a Porsche Car Insurance Quote
FOLLOW 911UK ON TWITTER
