997 : 2004- 71
996 : 1997-2005 35
Boxster : 1997- 25
Karl_996
PostPosted: Sun Aug 19, 2018 10:04 am    Post subject: Alpine ILX-700 wiring Reply with quote
Hello,
First post on here.
I’m looking for help wiring my 996 (2003) with a Alpine ILX-700.
I’ve got the old PCM2 out fine. I used the supplied wiring loom adapter and run a separate accessory power to the new head unit which now powers up.
Problem is I get no sound...
Note:
I have the Becker DSP amplifier and PCM2 RDW.
This is the wiring loom adapter I was supplied - https://www.dynamicsounds.co.uk/connects2-ct27aa17-universal-fakra-to-din-aerial-antenna-adaptor.html?search=ct27aa17&page=2
Anyone got ideas of what I’m missing (extra brain cells excluded)
Karl
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Sun Aug 19, 2018 10:13 am    Post subject: Reply with quote
Hi Karl,
The link you have is for an antenna adapter, nothing else. A common one to check is that any amplifier trigger output is present, that has changed between pinouts on different units. I am not sire when the PCM changed to optical (MOST) output. Post up more pinouts and info and I might be able to help.
Karl_996
PostPosted: Sun Aug 19, 2018 10:19 am    Post subject: Reply with quote
Sorry that was the wrong link:
https://www.dynamicsounds.co.uk/connects2-ct53-po01-porsche-911-boxster-active-system-amplifier-adaptor.html?search=ct53-po01
This is what I was provided.
Mine has an optical arial and two other optical connections. The CD changer is also via optical.
I will go out to the car now and post some pictures.
Karl_996
PostPosted: Sun Aug 19, 2018 10:47 am    Post subject: Reply with quote
Photo's:
Halcyon
PostPosted: Sun Aug 19, 2018 7:17 pm    Post subject: Reply with quote
Thankfully, mine didn't have MOST, so my advice will be limited!
So things to check:
Does the converter need power? Is it getting it? (Does it have an LED or anything?)
Is the amp getting power? That should have a more obvious LED
Have you wired the amp to use speaker level or phono / RCA cables?
If it is doing speaker level, are you using the car's loom to get the signal to the amp in the frunk?
In my car, that loom uses a common ground across the four speakers (so only uses 5 wires) and most amps that take speaker lever don't like that - so try connecting just one speaker line at the amp?
I ended up making up my own speaker cable loom Sad The amp does the doors and the H/U does the dash & rear panels.
996.2 Carrera 4 Convertible Tip
eabeukes
1999 Porsche 996 Carrera 2
PostPosted: Mon Aug 20, 2018 9:18 am    Post subject: Reply with quote
The adapter you have bought bypasses your factory amp (sound provided via the optical feed!)
What you need is one of either:
- adapter to feed optical from your new HU to the Becker DSP
EDIT: see here for the one you want
http://www.connects2.co.uk/Product/ProductItem/CT51-PO04
or
- wiring look to take new HU sound output --> speakers directly.
uk996
PostPosted: Sat Dec 15, 2018 9:41 pm    Post subject: Reply with quote
thought I'd just add to this thread.
I'd like to replace the original PCM with an Alpine ILX700.
Apart from this : http://www.caraudiodirect.co.uk/connects-2-ct53-po01-porsche-boxster-911-active-system-adapter-non-fibre-optic
What else do I need for my 996tt 2002 to fit the Alpine?
Also how does the old unit come out?
2002 996tt Aero in seal grey 6MT
