997 : 2004- 64
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 10
Cayenne : 2003- 4
Macan : 2014- 1
charandhindsa
PostPosted: Fri Aug 10, 2018 11:40 am    Post subject: 996T - Major Service (price....whats included?) Reply with quote
Hi All,
My car has been driven approximately 700 miles since 2016 and I've been advised a major service is recommended every 4 years regardless of mileage covered.
Question is, what does a major service consist of & what prices are quoted. Just had a brief chat with Brooklands and they characterise a major service as (1)
(1) - filters (particle / oil / air) / oil / sealing rings @ £698.
Additional Item (2) - spark plugs @ £492
My confusion is based on the fact that many indies include plugs in a 'major service' and often come in ~ £800
Am i comparing apple for apples here? i.e. £1190 vs. £820
Thanks in advance for any guidance...
911munKy
PostPosted: Fri Aug 10, 2018 12:40 pm    Post subject: Reply with quote
Do you live away from your car for most of the year? If not start driving it!
Who advised a Major service? When was it last serviced? (Major or Minor and mileage/dates) and when were the plugs, coil packs, brake fluid, gearbox oil etc last changed.
If they don’t need replacing then I believe you only need an annual check over service. It seems bonkers to spend that much for such little use. I think OPC charge much less than that for a Major anyway let alone an indy.
2000 C2 996
s70rjw
PostPosted: Fri Aug 10, 2018 7:26 pm    Post subject: Reply with quote
I use an Indy and had a major last week, together with an MOT and brake fluid. Major included spark plugs, hubs painting etc. £642. That's on a Gen 2 997 S, so maybe slightly cheaper than a 996 tt. Your best bet is to phone around and check. Some Indy's don't quote vat in their prices either. Where abouts are you in the UK ? Service parts deteriorate due to time as well as mileage.
997.2 manual
