964 : 1989-1993 6
Boxster : 1997- 18
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
stucart
PostPosted: Thu Aug 09, 2018 10:24 pm    Post subject: knocking from front???? Reply with quote
Hit a damn pothole with nearside front wheel (trying avoid another one!) Since then there is a strange knock/ thunk coming from that corner, doesn't seem to do it when hit a speed hump or rough road or when cornering, sounds like under tray is flapping but checked that and also visually checked around and nothing obvious???
Anyone any ideas what to check next????
Now - Jaguar F-Type 2014 3.0 S Quickshift ,White/ Red interior (theme here!) Loving it .
Previously - 997 C4S Tip-S, 2007, Silver/Red and Black Leather, PSE, Sports Chrono, Turbo wheels.
FZP
Paul Ricard
PostPosted: Thu Aug 09, 2018 11:07 pm    Post subject: Reply with quote
Is the knock a more inboard or more towards the wheels?
stucart
PostPosted: Fri Aug 10, 2018 6:37 am    Post subject: Reply with quote
Hmmm got me thinking now Frank, it does seem more inboard than the wheel, seems passenger foot position from drivers side, very difficult to tell, not a heavy knock like a worn joint, more a dull thunk?? Question
FZP
Paul Ricard
PostPosted: Fri Aug 10, 2018 6:44 am    Post subject: Reply with quote
Sounds like a coffin arm. The pot hole may have been the straw that broke the camel's back.
Magic919
PostPosted: Fri Aug 10, 2018 7:55 am    Post subject: Reply with quote
Get some chassis ears on there.
997.2 C2S PDK
997.2 C4S PDK
SJD
PostPosted: Fri Aug 10, 2018 5:12 pm    Post subject: Reply with quote
If it sounds like plastic rattling then it is your steering control arm.
I lived with that noise from when I bought the car and believed it was just the sheer volume of plastic parts under the frunk rattling about. How wrong I was!
SP Autobahn diagnosed and replaced the arms and noise gone!
Pays dividends to have a good Indy that you can trust.
MaxA
PostPosted: Thu Aug 16, 2018 11:15 am    Post subject: Reply with quote
I've had strange front end knocks from failed drop link bushes and failed top mounts. You just need to get a wheel off, and inspect everything, and poke at stuff with a pry bar.
2010 9972 C4S PDK: Carrara White, Sea Blue. Mostly driven, lightly modified, occasionally tracked, and usually a bit grubby.
