997 : 2004- 71
964 : 1989-1993 5
Boxster : 1997- 20
Cayenne : 2003- 4
DavidRussell
PostPosted: Wed Aug 08, 2018 3:59 pm    Post subject: Intermittent wipe now permanent Reply with quote
Advice needed for 1994 993 C2 - wipers work OK at all 3 speeds but when switched on to intermittent or wash they wipe at speed 1 and won't stop until the ignition is turned off.
Time delay has no effect; they just keep going at speed 1.
If you turn them up to speeds 2&3 then they speed up normally but revert to speed 1 in the stop or intermittent positions.
Is this the relay or something else that controls this function?
Thanks.
Endoman
PostPosted: Wed Aug 08, 2018 5:38 pm    Post subject: Reply with quote
It is controlled by a time delay relay and the rotary switch. The relays are very expensive iirc.
DavidRussell
PostPosted: Thu Aug 09, 2018 2:11 pm    Post subject: Reply with quote
Thanks - ordered a relay.
