964 : 1989-1993 5
Boxster : 1997- 18
Cayenne : 2003- 3
Macan : 2014- 1
MarkGolf
PostPosted: Wed Aug 08, 2018 12:49 pm    Post subject: Porsche 928 torque tube fix? Reply with quote
Hello all,
I'm on the hunt for my next project and a 928 has got my attention, it has issues, which I like but the car has 1 issue which scares me a bit and upon doing some online digging, it would be something I get someone else to deal with. It looks like the gearbox needs to come off, not something I am going to do on the drive at home.
Has anyone experience of getting this issue rectified, who does it and what is the going rate?
I am assuming it is the torque tube, a friend who had the issue (sold the car with the issue) said it sounds identical to his and he sold the car as no one wanted to do the job! Ekkk
Here's a vid
https://www.youtube.com/embed/jIOtkvP1hLo?rel=0
Current fleet
My 964
My 997
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
1995 VW Golf VR6 3.0
igaffz
PostPosted: Wed Aug 08, 2018 10:25 pm    Post subject: Reply with quote
So do you think it’s the bearings? I’d take it to your local Indy for there opinion. Get the flex plate checked while your on. What year is it?
My S2 goes to a new home on Sunday 😩
The older cars are suffering with rust really badly now, sills, inner sills, front of rear wheel arches and around the filler cap. Check the fuel lines, especially as one runs around the rear driver side wheel arch. The heating systems a bit of a nightmare also so check it blows hot and cold.
Timing belt/water pumps an easy job once you’ve moved everything out of the way and sump gasket leaks are common, also if there’s oil drips around the alternator/oil filter area this could be oil cooler pipes leaking but not to hard to fit new crunch washers.
I’d just add mines never let me down in 3 years, when sorted they are very reliable 👍🏻
Horizon blue, 964 carrera 2 tip, lowered on koni's, k&n, de-cat, cup pipe, leather trim and 18" 3 piece split rims.
Silver 928 S2, B reg, manual.
Guards red 944 lux, the new project!
MarkGolf
PostPosted: Wed Aug 15, 2018 10:19 am    Post subject: Reply with quote
Cheers mate!
Ahhh shame, I loved the colour of yours!
I've decided against the 928, just required too much and too many unknowns for me, the torque tube looks like a nightmare of a job!
Current fleet
My 964
My 997
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
