997 : 2004- 64
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 10
Cayenne : 2003- 4
Macan : 2014- 1
Norfolk & Idea
PostPosted: Wed Aug 08, 2018 10:44 am    Post subject: Changing pads and discs- Easy enough task? Reply with quote
As above, I'm handy enough on the spanners and imagine I could do this easy enough. Done it countless times on the bikes.
Any special tooling required? Pointers? Which quality pads and discs? I'll look up torque settings later. 997.2 turbo btw. Cheers, Paul.
2012 997.2 Turbo Basalt Black. Bit of a 9E ing.
2008 Ducati 1098R (Track)
2016 Macan GTS
2008 Vito Sport- Household Star!
2018 Ducati Panigale V4S (Track)
PGD
PostPosted: Wed Aug 08, 2018 11:22 am    Post subject: Reply with quote
Very easy yes. I've just done mine and everything came apart and went back together very easy. Easier than most cars I've worked on.
Take the rear arch liners off while your there. See my post about that
http://911uk.com/viewtopic.php?t=129321
997.1 C2S
Norfolk & Idea
PostPosted: Wed Aug 08, 2018 12:08 pm    Post subject: Reply with quote
Ahh, I did see that. Thanks very much for your reply Thumb
I guess that's a Sunday morning sorted...
2016 Macan GTS
hedgehogsdad
PostPosted: Wed Aug 08, 2018 12:40 pm    Post subject: Reply with quote
I've done the rears on my 997.1 Turbo and they were easy, other than the handbrake shoe liner came away. I'm going to do the fronts soon.
I also forgot to take the bungee cord out which I suspended the caliper from and only found out when it went into OPC Chester for a service. frustrated Floor
2006 997 Turbo
2003 996 Turbo
2006 Cayenne
1999 996 C2
1990 964 C2 Targa
1980 SC
PostPosted: Wed Aug 08, 2018 6:53 pm    Post subject: Reply with quote
T 55 i think for the caliper bolts , one of the large ones anyways .. without looking at what i normally use i cant be 100% sorry Sad
All i would say .. undo the caliper bolts .. they should be tight ( obviously ) but then go loose and easily come out .. if they stay tight and really dont want to come out then nip them back up and take it to your indy as they will probably strip the threads and need drilling / helicoil .
i doubt it on a gen 2 but best if you are aware of it before you do it .
