996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
PostPosted: Mon Aug 06, 2018 1:32 pm    Post subject: Reply with quote
isysman wrote:
I have one of these units and I find it to be frustrating. It works sometimes immediately and then I get our of the car to buy fuel or a Starbucks and then it will not re-pair with the phone. I can't see the phone then I restart the PCM and it sees it but won't play the music, or it plays the music from my phone although I can control it on my PCM, then I restart the phone and the PCM and eventually it works. It's a great idea in principle and on a long trip when you are in the car for a few hours it's fine, but if you are getting in and out it's a faff.
I also find that often when it does pair with the Bovee when I go into Bluetooth settings the phone part did not pair and I have to do it manually.
Don't know if my unit is faulty but that is my experience. And it's behaved this way with two phones.
No I dont think yours is faulty mate mines the same.As I said further up its a decent option to enable you to stream but like all these things that interface with the PCM it can be a bit clunky mine even saysconnected to bovee on the phone but the PCM says its not , then a few mins later its connected . its not perfect but it is all thats available to stream unless you go for an aftermarket head unit. I am not using the laterest software flash for PCM maps etc so there maybe some bug fixes in the latest maps software which might explain why some find it works perfectly and others that its a bit clunky Thumb Thumb
Geezer 911
PostPosted: Wed Aug 08, 2018 7:09 pm    Post subject: Reply with quote
Problem solved thumbsup
The Y cable was broken. Just received a delivery of a new one it works straight away Thumb
If a you have a Gen 2 and don’t have a Bovee I recommend getting one Thumb
Busterwebb
PostPosted: Thu Aug 09, 2018 10:37 am    Post subject: Reply with quote
A question - I have the original Porsche PCM audio interface cable that connects the USB/Aux inputs to an old iPod/iPhone with the 30 way connector. The Apple ‘official’ 30 way to lightning connector then interfaces this with my iPhone 6s and both charges it and interfaces the apple music library and Spotify (though I can’t control Spotify from the PCM screen).
All works perfectly. So does the Bovee interface offer anything more other than wireless connectivity?
997.2 C4S PDK cabrio aqua blue
2016 M-B CLS Shooting Brake (hmmm)
2007 Nissan X-trail
2005 Vauxhall Agila (sorry)
2008 Triumph Tiger 1050 (not sorry)
PostPosted: Thu Aug 09, 2018 12:22 pm    Post subject: Reply with quote
Spotify etc can be controlled within reason through the PCM with Bovee the biggest advantage is that your phone stays in your pocket and you dont have to mess around conecting it with cables. the iPod option was what I originally had and if all you want to do is listen to an album from your library on your old ipod then what you do is fine,but if you want to access spotify premium or deezer or any of the other music streaming services so you get "all the music in the world ever " to your PCM and have some visual interaction with the PCM while keeping your phone in your pocket, then the Bovee1000 or similar is what you need along with the Y cable that uses the porsche ipod port in the armrest console its this port that I believe gives you the interaction with the PCM doing it the other way using aux and usb allows the sound to access the speakers via the PCM but theres no interface . Thumb Thumb I would try buying the porsche Y cable £30 from the OPC this will allow you to connect to the Porsche Ipod port connect manually your old phone try spotify if that works and intefaces with the PCM giving you some functionality on the PCM, then the only advantage of the bovee would be the wirelessness, and if you dont need that then your good to go. Thumb
boardingnath997
PostPosted: Wed Jan 09, 2019 8:56 pm    Post subject: Reply with quote
I've used my Bovee without issue for the past 18 months and now it seems that it is not working at all. Have tested the Y cable with an iPod and it's working so not a cable issue. Phone can connect to PCM so not a phone issue, just seems like the Bovee is not on or working at all. Any ideas on troubleshooting?
James M-S
2009 Porsche 997 Carrera 2
PostPosted: Thu Jan 10, 2019 4:13 pm    Post subject: Reply with quote
Only the obvious advice.
Is the blue light showing on the bovee? If not, check all connections and whether you have power coming from the usb socket. (Eg plug charger cable in)
Or you could try cig lighter adapter for usb power source.
If you have power, delete the bovee from your phone Bluetooth list and try to pair them again.
Dont know
Goto page Previous  1, 2
Page 2 of 2
