997 : 2004- 77
996 : 1997-2005 39
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 12
PostPosted: Mon Jul 30, 2018 2:11 pm    Post subject: Strange running issue 997.2 any ideas Reply with quote
Myself and my Porsche tech have been struggling with a difficult to diagnose fault , car was running ok then started to missfire at revs over 3800 about where the timing values change , missing on one cylinder only, but kept moving between the cylinders and across both banks , so decided to change the 4 solenoids on the DFI engine the two top and two side ones , this improved it but during a good road test the problem returned after about 4 miles of ok running its now missing on 2,4,6, disconected the maff to see what would happen, no change problem still their so it wasnt the maff playing up. no fault codes just the check engine light on the dash. very strange , have filled up with vmax on the road test to discount a batch of crappy fuel . theres a noticable lack of power on the road test even though the engine initially was running ok until the fault returned. have considered cam solenoids but would have expected a fault code for that.
anyone had similar or can throw some ideas my way Thumb
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Mon Jul 30, 2018 9:41 pm    Post subject: Reply with quote
Sorry to hear you've got more grief Phil!
As we discussed in the 'other place' (!) I think I'd check if it needs the HP fuel pump campaign was done first.
Sounds like you've ruled out dodgy fuel, high lift solenoids, maf.
Can't be coil packs - those faults wouldn't 'move', so seems most likely to be FP to me.
Good luck sorting! - where's DeMort?
Very Happy
PostPosted: Mon Jul 30, 2018 9:57 pm    Post subject: Reply with quote
thanks Jon, yes I am leaning very much towards HP fuel pump , it may have been replaced as theres no outstanding campaigns on my car but it may well have gone again as as its a known issue with early gen2 and has symptoms like we discussed I have it ,makes sence to investigate that next and either solve it or rule it out. Thumb Thumb thanks for your thought mate its a great help. dam chocolate gen2s I need another reliable gen1 Floor Floor Floor
Shanghai
PostPosted: Tue Jul 31, 2018 3:27 am    Post subject: Reply with quote
Hang on I'll stop you there! On my 3rd never a single problem! Plus if there were I'd drop it at the OPC tell them to make it right I'll collect it later Grin Hand
991 C2S X51 powerkit PDK in racing yellow, PCCB, PDCC, PSE, Sports design kit, ducktail.
EX 997.2 Carrera 4S PDK
EX 997.2 Carrera S PDK
EX 997 C2 gen 2 PDK
EX 993 Targa
EX 993 Carrera 4 manual
EX 996 3.4 Cabriolet
jonno_
PostPosted: Tue Jul 31, 2018 11:43 am    Post subject: Reply with quote
How's the investigation looking?
Did you manage to get the injector correction stats?
PostPosted: Tue Jul 31, 2018 6:52 pm    Post subject: Reply with quote
Sorry young man .. im not as active as i was atm .. faults like this and you really should phone me asap Thumb
You have changed all the solinoids .. vario cam are the top ones with high lift being the ones in the middle of the head.
Im afraid none of these was likely to be the fault .. each one only effects a single bank and each can be seen on a tester on the actual values section... gen 2 only i might add .
I take it you have a misfire on one or more cyls at higher rpm which moves to different cyls .. is that the only fault codes you have .. random misfires ?
Nothing else at all ?
Fuel pressure in this case is the most obvious but normally anything related to the high pressure pump will throw up a code .. ive not yet seen one that didnt .
Low pressure pump is possible .. i would have thought you would see a low injector pressure though .
To check you need to look at the values for the pump on idle .. your looking for about 45 bar but you also check the specified fuel with the actual .. they should be pretty much the same so you would rev the car and watch the figures .
Other things .. DFI engines do suffer from build up on the valves .. this is more a general lack of power not a misfire as such .
Your guy also needs to look at the short and long term fuel trims .. is it rich or weak at low , mid or high rpm ... Rkay , Frau or Frao .
Phone me if you want .. usual times Smile
jonno_
PostPosted: Tue Jul 31, 2018 7:44 pm    Post subject: Reply with quote
Ah, Iain, such a credit to this place!
Hopefully that'll help tie things up!
PostPosted: Tue Jul 31, 2018 10:43 pm    Post subject: Reply with quote
Floor Floor Floor Thumb
PostPosted: Tue Jul 31, 2018 10:50 pm    Post subject: Reply with quote
Hi Iain, mate I was hoping you would see this , thanks for all the info I will pass it all along to my guy , they are round thurs even with PIWIS to look at fuel pressures , mixtures and all the other fuelling linked areas etc etc ,I have ordered a crankshaft sensor to try that no idea if it would help , having no codes is a pain just the missfires showing , when I get it running right what can I use to clear any build up on the valves . I will see how I get on Thursday and failing that I will give you a call mate at the usual times Thumb Thumb
PostPosted: Tue Jul 31, 2018 10:51 pm    Post subject: Reply with quote
100% agree Jon. Thumb Thumb Thumb
PostPosted: Wed Aug 01, 2018 7:10 pm    Post subject: Reply with quote
Bless you both ..
Ok .. ill do my best to remember to bring home a manual i have .. it explains a lot of the terms that your guy will be looking at on the tester .. trust me i did a similar job today on a gen 2 and i had to reference a lot of the readings as to what they actually mean ..
Your guy will know what i mean !!
That way you can phone me if needed .
Tell him to run the short test section .. its only fuel load at partial load he cant do unless the car is driven .. all the others can though .
Theres one reading but i cant dam well remember atm that needs checking .. H20 or H 30 i think .. its about how the engine is adapting over all .. ill have to look it up tomorrow .
Unfortunatly there is an awfull lot of things the car tells us with a tester .. but understanding them all and knowing what the proper base setting should be confuses me and i guess many of us Mechs .. hence i need my manual Very Happy
btw .. i got a new phone .. one of these smart phone things .. video calling .. would that work to show me pictures of the tester and readings on it ?
Yup .. im not into phones that much .. i just thought they made phone calls !
PostPosted: Wed Aug 01, 2018 9:51 pm    Post subject: Reply with quote
Thanks Iain hes round after work tommorow , I will show him everything you have suggested and if hes stuck I will call mate Thumb thanks again for all the info and suggestions Thumb
PostPosted: Fri Aug 03, 2018 2:18 pm    Post subject: Reply with quote
update,
Today changed the crankshaft sensor as it was the last of the easy things to try, still no luck running lumpy even on low revs , the guy with the piwis was a no show so decided to take it to the OPC for two hours of diagnostics to try and fathom the issue , drove the car to the OPC only a couple of miles and stayed in low revs it ran lumpy but go there ok. OPC have phoned they have checked the oilfilter and see shiney metalic film in the filter , the oil and filter were only changed monday and it has a magnetic sump plug . so it seems the issue may be mechanical they want to open it up and check the tappets, valves etc as they suspect one may be breaking up. they are going to have to open it up to find what the metalic bits are. logically the sort of sticky tappet noise it makes from time to time may be the culprit.
Its very difficult to diagnose a missfire when its random across both banks and there are no fault codes and also frustrating as I feel like I keep spending money without a definitive diagnosis .Even the OPC are saying they cannot be sure it tappets but they do need to find whats happening and the only way seems to be to open it up . Three engine drops since the new year is starting to take the piss though, but if I am to regain confidence in this car I need to get to the bottom of it. nooo updates to follow Thumb
FRZ 911
2007 Porsche 997 Carrera 4S
PostPosted: Fri Aug 03, 2018 2:53 pm    Post subject: Reply with quote
Phil, you're definitely having no luck at all. Hopefully this will be the last issue for a while and you can get back to enjoying the car. All the best fella.
997.1 C4S Meteor Grey Manual
PostPosted: Fri Aug 03, 2018 3:44 pm    Post subject: Reply with quote
Thanks Frank , me too . I can see the bill for this year another few grand taking to over 10k this year which is a bit dishartening after all the singing of how good these cars are lol. but on a positive note if they can sort it without to much extra cost my ave during 911 ownership excluding mods will still only under £2500 pa as an ave. its just one of those ave where there was not much in the first few years with the gen1 and a big hit all together with the gen2 so fingers crossed after this episode it will be trouble free for a couple of years bringing my ave back down to 2k pa. which to be honest isnt bad for driving a car like the 911 . if you count the 3k profit I made selling the gen1 actually my ave is still around 2k PA .thats my man maths equation but doesnt stop my bank manager frowning at me this year Grin Grin Grin
Shanghai
PostPosted: Fri Aug 03, 2018 3:49 pm    Post subject: Reply with quote
Phil feel for you, you not having good luck at all nooo
EX 997 C2 gen 2 PDK
EX 993 Targa
PostPosted: Fri Aug 03, 2018 3:53 pm    Post subject: Reply with quote
thanks mate, Thumb Thumb
FZP
PostPosted: Fri Aug 03, 2018 4:33 pm    Post subject: Reply with quote
Phil, considering you had such a good run with your last 997, it seems like you've got the short end of the stick. Wishing you a speedy resolution, perhaps logging a call with the guys that had it last to see what they might be able to shine a light on? Just a thought. Good luck mate Thumb
PostPosted: Fri Aug 03, 2018 5:48 pm    Post subject: Reply with quote
I dont think they can help anymore than the OPC mate , Its had so much done to it and I dont drive it like miss daisy lol its does a min 12pa and is driven spiritedly after warming up. so things are going to go ping from time to time.and if the previos owners were lucky and had no big bills like I was with the gen1 then someone at some points going to get some bills . Thumb just seems like lots of the guys down this way are having a run of issues at the moment, we joked the other day saying we couldnt put together one decent 911 between the lot of us at the moment Floor Floor
PostPosted: Fri Aug 03, 2018 6:32 pm    Post subject: Reply with quote
Im sorry young man .. i have a good idea whats probably going on and it makes sense to me why it was better after the valve change now .
A strip will confirm and ill not go into what i think here but you are welcome to phone me if you want a chat as always .. ill be in all weekend if you want to .
Well .. not sat morning .. haveing a look at a problem on James 996 but sat afternoon onwards .
It probably doesnt help but this is pretty much a one off .. depending on what they find .
