996 : 1997-2005 43
Boxster : 1997- 13
Macan : 2014- 0
Teg
PostPosted: Sat Jul 21, 2018 1:10 pm    Post subject: wishbone removal help :) Reply with quote
Hi All,
Doing some suspension maintenance on my 996 turbo.
Top mounts done and drivers side coffin arm done.
The problem i have is the passenger side coffin arm is stuck solid! Have got all the bolts off no problem, but cannot separate the ball joint from the hub.
I have a ball joint removal tool which worked fine on the other side and had worked well with cars in the past, put this one has bent it!!!!
What are my options?
Is it possible to drill it out? I don't want to damage the hub though.
Any thoughts experiences would be much appreciated.
Ben
PostPosted: Sat Jul 21, 2018 2:15 pm    Post subject: Reply with quote
Well ..
Your going to need another ball joint splitter , you need the coffin arm connected at the far end or at least a bolt through it to stop it moving.
Tighten up the ball joint splitter but dont keep going untill it bends you can then try hitting the part the ball joint goes through .. give it a try but dont go mad.
Spray any kind of penetraiteing oil on the ball joint and basically leave it for a bit.
Ive had one go after 5 mins of being left under tension .. thats about x1 fag break Very Happy
Heat is not really going to work but a hot air gun is worth a go .. anything flame based and you risk melting the hub.
Worse way .. it will come out but the steel insert will come out as well .. thats a new hub im afraid .. dont attempt to refit it if that happens .
Teg
PostPosted: Sat Jul 21, 2018 3:01 pm    Post subject: Reply with quote
Thanks DeMort
Good idea to keep the other end of the wishbone connected. I had it off so could not put any force down on this.
Yeah tried a little bit of heat but was cautious of over heating the hub so don’t get it that hot really.
Any recommendations on penetrating fluid? Been using wd40 but perhaps there is something better on the market these days.
Will get myself another hefty looking ball joint splitter, put it under pressure and give the wishbone a wack with a mallet.
Don’t fancy replacing the hub 😬
PostPosted: Sat Jul 21, 2018 3:14 pm    Post subject: Reply with quote
Something like Plusgas .. WD40 is a general purpose spray really .
Leave it under tension is your best bet and dont go mad with that mallet young man Hand
IanG1
PostPosted: Mon Jul 23, 2018 12:20 pm    Post subject: Reply with quote
As above leave it under tension then tap the side of the arm itself a few sharp taps. Leave then add a little more tension. Walk away for 5 minutes then tweak again. It will go with a bang when you least expect it.
1998 996.1 C2 manual/LSD with aero and a big smile
Teg
PostPosted: Mon Jul 23, 2018 6:28 pm    Post subject: Reply with quote
No luck yet frustrated
Left it under tension whilst I went to do the food shop. Covered in penetrating oil. Bought a decent mallet and given it a good few knocks to try and break any corrosion and it’s still stuck solid!
Just can’t believe how tough it is in comparison to the other side.
Will have another go this weekend, but not sure what else I can do.
If worse come to worse, where can I buy a replacement hub? Passenger side front.
PostPosted: Mon Jul 23, 2018 7:09 pm    Post subject: Reply with quote
You need to check part numbers here as im not sure this will fit but its a 996 number ..
https://www.ebay.co.uk/itm/Genuine-Porsche-986-Boxster-2-7-Front-N-S-Wheel-Hub-and-Carrier-Used-99634165811/162472698310?epid=646295461&hash=item25d420a1c6:g:4egAAOSwAANY71Ey
OR
https://www.ebay.co.uk/itm/113104618380
For now .. do the ball joint splitter up as tight as you dare and leave it .
Teg
PostPosted: Mon Jul 23, 2018 8:03 pm    Post subject: Reply with quote
Thanks.
Think tomorrow I can work from home so going to get it jacked up in the morning put the ball joint splitter on it and some plusgas and return at the end of each hour to give it another tighten.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Mon Jul 23, 2018 8:34 pm    Post subject: Reply with quote
You need a turbo or C4S front upright. The caliper bolt spacing is different to the C4, and the angle of the strut is different to the GT3 and GT2. Both things are different compared to a C2 or Boxster. Unfortunately they are rarer and more expensive.
Teg
PostPosted: Tue Jul 24, 2018 12:18 pm    Post subject: Reply with quote
Dance Tap Dance Tap Dance Tap
Its off! Whooop Whooop!
Thanks for your help guys, kept me motivated to keep at it. Real feeling of satisfaction after putting all those hours into it.
Heat was what finally got it out. Had spent all morning tightening it and spraying more plusgas. Then went for some heat whilst having the ball joint splitters on it and it finally popped.
Took a bit of work getting it out as the top of the thread was so mashed it would not fit through the hole, but its done now and car back together thumbsup
Couple of weeks before it goes in for geometry though.
madalaa
2009 Porsche Boxster 987
PostPosted: Tue Jul 24, 2018 12:52 pm    Post subject: Reply with quote
...... congratulations ...... Thumb
