997 : 2004- 71
Boxster : 1997- 13
Trap 125
2004 Porsche 996 GT3 Mk2
PostPosted: Sun Jul 15, 2018 8:52 pm    Post subject: 996.2 GT3 brake disc set up Reply with quote
What is the perceived wisdom with running PCCB discs at the rear and 2 piece floating discs at the front of the car? Would the break bias be out of sorts? My thoughts are that it would be ok...
'96 Guards Red 993 Carerra C2, HB seats, RS steering wheel, front turbo PU, Bilstein HD's, HID's, RS engine mounts, Motor Sound Pack, Dansk mufflers & cat bypass, Wayne Re -map 305bhp
2004 996.2 GT3 Clubsport
NXI20
Paul Ricard
PostPosted: Mon Jul 16, 2018 5:40 am    Post subject: Reply with quote
There is relatively little braking done by the rear on the 996 so yes, it's "ok". However, you will get a better pedal feel if you convert to steels & the appropriate pads. 997.1 rear discs are a direct fit and not expensive.
Nick
1978 Carrera SC Barn Find in Red (restoration project)
Trap 125
PostPosted: Mon Jul 16, 2018 1:42 pm    Post subject: Reply with quote
Many thanks for your reply. When you say "appropriate pads" for the rear do you mean standard pads or something more performance orientated?
NXI20
Paul Ricard
PostPosted: Mon Jul 16, 2018 1:47 pm    Post subject: Reply with quote
Something that will match the front. If you have floating fronts I’m assuming you have something like RS29s so that’s what I’d be using on the rear too.
Nick
Trap 125
PostPosted: Mon Jul 16, 2018 1:48 pm    Post subject: Reply with quote
Great info. Thank you very much!
