997 : 2004- 78
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 20
Cayman : 2005- 11
Haywoon
PostPosted: Thu Jul 12, 2018 6:36 am    Post subject: Quorn Sports & Classics - Great Service Reply with quote
I collected my 996 4S yesterday after having Quorn Sports & Classics fit a new clutch and updated IMS bearing alongside a new RMS and a few other bits and pieces sorted out.
The garage is run by Carl and Nathan who are both ex Leicester OPC mechanics and were recommended to me.
Based on my experience if you are in the Midlands I can highly recommend these guys. Very professional, do exactly what they say and very friendly too. Plus they kindly documented all the works with plenty of photos which they sent on to me to keep with the history. Very pleased indeed.
They said the original bearing was in pretty good condition after 66k miles other than a small amount of play in it.
The original bearing on the left and the new one on the right
‘02 996 4S Coupe in Polar Silver
911munKy
PostPosted: Thu Jul 12, 2018 7:36 pm    Post subject: Reply with quote
Always good to recommend a quality service centre but hang on I’m confused
Question
It looks like you’ve had a single IMS bearing replaced by a wider dual row one, I didn’t think that this was possible (I’ve obviously got my wires crossed as i didn’t think that a dual row bearing would retrofit in the space for a single row bearing just visa versa with a spacer to fill in the bearing width differences)
Also which make of bearing did you have fitted please.
Thanks,
2000 C2 996
bakerboy4s
PostPosted: Thu Jul 12, 2018 8:04 pm    Post subject: Reply with quote
Unless it's an optical illusion it looks as though the 'retainer' is thinner on the new bearing hence allowing the wider bearing Dont know
Haywoon
PostPosted: Fri Jul 13, 2018 6:21 am    Post subject: Reply with quote
Yep you’re right the retaining cover is thinner I believe to accommodate the larger bearing. I’m not sure of the make fitted I didn’t think to ask.
INWB
PostPosted: Fri Aug 03, 2018 3:26 pm    Post subject: Reply with quote
Rang them today as they are very convenient to where I live. Quoted 6 hours to do RMS seal and said may as well do clutch and perhaps IMS at same time as just need parts. Labour would stay the same.
Thinking of putting in a lightweight flywheel at the same time.
Dare I ask how much your little lot cost?
2003 Manual 996 C4S Midnight Blue
PostPosted: Fri Aug 03, 2018 7:22 pm    Post subject: Reply with quote
Quorn doing Pork Dont know
Haywoon
PostPosted: Sat Aug 04, 2018 8:06 am    Post subject: Reply with quote
Sure here is the detailed breakdown of works carried out:
INWB
PostPosted: Sat Aug 04, 2018 10:23 am    Post subject: Reply with quote
Cheers - appreciate that.
Wife will be pleased !
Already spent £4.5K on the thing this year so was hoping I wouldn't have another big bill. This will make the cost in the last 3 years £12,000.
Don't think the car would get £35K somehow.....
On the other hand that only leaves the suspension - although I've done the coffin arms already.
Haywoon
PostPosted: Sat Aug 04, 2018 10:58 am    Post subject: Reply with quote
No problem at all, happy to help.
Mine's back in this coming Thurs to have one of the air con pipes replaced which has fractured.
Then on the list is a bit of knocking from the front ends - suspect drop links and after that, hopefully nothing for a little while!
Although I am considering sorting out the interior audio as the becker amp is shagged but I'm loathed to put an after market head unit in it and I dont really want to just swap the amp with a used one with the risk the same thing will happen further down the line.
Choices choices!
INWB
PostPosted: Wed Aug 15, 2018 9:12 am    Post subject: Reply with quote
Saw your car this morning when I dropped it off. Very impressed by the condition of the paintwork. Have you had a respray recently? (If so where as Chartwell prices are extreme).
Looks a really decent C4S with some mechanical stuff (exhaust, manifolds) no doubt on the "to do" list. Smile
Thanks for the heads up on these guys - they are literally 10 minutes from home.
(speaking of which - do you plan on going to Quorn Manor pubs classic car meet on first tuesday of the month?) I can't make September but if held I will be going in October.
