996 : 1997-2005 42
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
Pops
PostPosted: Wed Jul 11, 2018 4:50 pm    Post subject: Brake Pads - 2013 Cayenne S 4.2 Diesel Reply with quote
I recently bought one of these and have been enjoying it immensely. As part of the PPI I was advised that the front and rear brake pads, but not discs would need replacing at the next service. The vehicle is not under OPC warranty so I would like some recommendations as to which make / brand of pads I could use other than the Porsche stamped ones, bearing in mind the weight and performance of this model. Thanks.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Wed Jul 11, 2018 5:14 pm    Post subject: Reply with quote
I generally go with Pagid. I recently paid about £60 for a set of Cayenne front pads from ECP.
PostPosted: Thu Jul 12, 2018 7:44 pm    Post subject: Reply with quote
I must have missed this post so il just copy paste what i replyed via PM for anyone thats interested .
Hi Pops
Im a bit of a Porsche fan im afraid so i do personnely prefer Porsche parts but at work i tend to fit what im given and if there is a choice then that is offered to the customer , for anything like this we would offer what ECP stocks and Porsche so the customer can decide .. all i can recomend is you check ECP and see what they offer .
Bear in mind the front brake pads are only 1 cm pad material from new , lots of people even opc tend to say they need changeing when they dont .. its a huge pad so it has less material but it confuses people.
Front and you need to be down to 3mm before changeing them or wait till the warning light comes on .
Iain.
Pops
PostPosted: Fri Jul 13, 2018 6:14 am    Post subject: Reply with quote
Many thanks chaps for the replies.
Very interesting about the Cayenne pads only being 1cm thick when new.
The PPI inspection I had on the vehicle may not have taken this fact into account when they flagged the brake pads as needing replacing at the next service. The recently obtained service print out, which the PPI inspector was not party to, showed that the pads where replaced at the last service (11,000 miles ago), so I was surprised when advised these would need replacing so soon!
PostPosted: Fri Jul 13, 2018 7:25 pm    Post subject: Reply with quote
Rule of thumb .. front pads/discs at 20k miles but this REALLY depends on how its driven .. they can last far longer .
Wait till the pad warning light is on .. only THEN replace them .. ignore the garages .. the car will tell you when its warrented .
If they were a cheap ish replacement then fine change when reported .. but they aint so get all the use out of them you can !
Pops
PostPosted: Sat Jul 14, 2018 12:30 pm    Post subject: Reply with quote
Great advice, many thanks De Mort! Salut
