996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
Boxstercol
PostPosted: Tue Jul 10, 2018 4:26 pm    Post subject: Over rev question... Reply with quote
Hiya chaps,
Just a simple question... Will an over rev be logged by hitting the rev limiter whilst accelerating, for example in 2nd gear?
Asking for a friend....
Cheers.
Slayer
PostPosted: Tue Jul 10, 2018 4:48 pm    Post subject: Reply with quote
I think it happens when you shift down into the wrong gear e.g. 5 to 2 instead of 4th or similar. Hitting the rev limiter may not be an over rev.
I may be wrong Question
Current: Golf R 7.5 FL ( Atlantic blue with Akropovic exhausts/ Performance pack)
Sold:
Golf R FL 7.5, A45 AMG FL, Golf R , Golf GT, VW Golf R (Reflex silver) 2016
VW Golf R, Golf Match, VW Scirocco 2TDI R line-BMT , 997 Gen 1 Turbo , 997 C2S(Aerokit), 997 C2S, Cayman S, 997 C4S, 997 Carrera, Boxster
IanG1
PostPosted: Tue Jul 10, 2018 4:56 pm    Post subject: Reply with quote
Yes it will but at the lowest level on the over rev scale. If I recall there are 5 levels on a 997, I have a 996 which only has 2 levels and hitting the limiter counts as an over rev.............changing down is far more damaging and records at the higher levels if you get it wrong.
1998 996.1 C2 manual/LSD with aero and a big smile
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Tue Jul 10, 2018 5:03 pm    Post subject: Reply with quote
Downshifting a manual incorrectly is usual cause.
But others depend on engine, 'box, going downhill and 'airtime' .
Everything else being equal, the DME cuts fuelling, but that's not always going to work if you're maxed out on a huge downhill, airborne or trying to shift into 2nd > 100mph in a manual.
Magic919
PostPosted: Tue Jul 10, 2018 6:02 pm    Post subject: Reply with quote
You might see ranges 1 and 2 without mechanical over-revving.
997.2 C2S PDK
997.2 C4S PDK
Ptabi
PostPosted: Wed Jul 11, 2018 1:27 pm    Post subject: Reply with quote
Rev range is stored in the cars ECU. In summary it’s downshifting to the wrong gear e.g from 5 to 2 when the car is travelling at high speed which then leads to over reving in the below ranges.
Range1 - 6800 - 7000
Range 2 - 7000 - 7200
Range 3 - 7200 - 7400
Range 4 - 7400 - 7900
Range 5 - 7900 - 9000
Range 6 - 9000 and above
Range 3/4 potentially can be an issue but 5/6 more serious especially if within 200 operating hours.
I understand over Rev data on PDk transmission cars are ordinarily not considered to be a concern provided everything else checks out fine.
From what you have described you have not done anything which should give you any concern.
Offcause driving at long periods in the red zone is not good for your car because it is extra strain on your engine but if you are hitting the red line then that’s fine. I have done some research on this and these are my conclusions unless someone else disagrees.
2012 997 Turbo S
2008 997 Turbo 1.5 (Sold)
jonno_
PostPosted: Wed Jul 11, 2018 1:47 pm    Post subject: Reply with quote
Ranges are specific to the engine - Carrera will differ to turbo, GT3 etc.
