996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
TonyP-P
PostPosted: Sun Jul 08, 2018 7:13 pm    Post subject: Weird Battery/Starter Problem (996 C2 3.4) Reply with quote
Hi, I've got an odd problem with my 1999 C2.
I keep it on a trickle charge now, and have just replaced the battery (Bosch) so this isn't the usual issue about the battery running down quickly when not used (although i've been through that too, hence the trickle charger...).
On a long drive, if I stop after around 2 hours of motorway speeds, I'll often find the car reluctant to start if I try soon after stopping (like after a fuel stop). It has a weedy attempt to turn over but fails to start. If I try again, even after 30 seconds or so, it (often, not always) manages to start, not eagerly, but turning over enough to fire up.
On a longer drive (3 or 4 hours, including a fuel stop like the above) once I park up if I try to restart it again fails to turn over, and doesn't respond to a second or third attempt. BUT, if I just leave it for a few hours (without the charger) it will then start happily (i.e. turning over eagerly).
Now I don't think the battery is magically recharging itself, so I suspect that this is something to do with heat in the engine bay, but beyond that I'm baffled.
When driving the volts are running at around 13.5 v which I think is normal.
Any ideas?
PostPosted: Sun Jul 08, 2018 8:12 pm    Post subject: Reply with quote
Most likely its a starter motor fault .
If the alternator is working then its chargeing the battery , i cant see a totally dead battery in this situation and a discharge would not be this quick.
It could be an earth lead fault to the engine .. o/s/r or a battery earth lead but from experience its normally a starter faulty .
TonyP-P
PostPosted: Sun Jul 08, 2018 8:42 pm    Post subject: Reply with quote
Thanks. I did have the main earth strap cleaned up last time I had some work done on it, so that ought to be OK, but the starter motor or connection to/from it could be the culprit. Is this likely to be something that resolves itself when the engine cools down as happens with mine?
misterw
PostPosted: Mon Jul 09, 2018 8:29 am    Post subject: Re: Weird Battery/Starter Problem (996 C2 3.4) Reply with quote
Any ideas?
This sounds very similar to my recent problem
Car had a recent new Bosch S5 battery, kept on a trickle charger and turned over slowly (and once not all) when warmed up
Northway as a part of the next service diagnosed the starter motor as on the way out and changed it along with the live cable - now starts on the button every time now
996 3.4 C4
lapis blue
Stoo.c
PostPosted: Mon Jul 09, 2018 12:51 pm    Post subject: Reply with quote
Its normally when hot that the starters show signs of struggling with these so I reckon that's your issue.
02 996 C4S
93 Skyline R33 GTS-t
91 CRX vtec turbo
01 986 Boxster S
996lee
PostPosted: Tue Jul 10, 2018 1:28 pm    Post subject: Reply with quote
mine has just recently started doing the exact same thing
and just yesterday made me look a Kn*b at the petrol station
straight after i received a "nice motor mate" comment Embarassed
hasn't actually failed to start but struggles when hot.
2001 Carrera 4 aero all the way!!
