key
Samurai
24 May 2015
59
Hi, has anyone had any experience with the key being a little difficult to get get back ????
I've had a few close calls pulling out but I tend to be pushing back in soon after :thumb:
Could it be the steering lock is interfering? Have you tried wiggling the steering wheel as you're inserting the key to rule that out. Is the key excessively worn and does it do the same with the spare. Failing that I'd be tempted to drop in a squirt of WD40 to see if that resolves it.
Get back meaning unable to turn off or remove the ignition key ?
If so its the ignition lock and the switch pack at the rear that causes it .. i replace the entire ignition lock but others here have had success just replaceing the connector at the rear of the lock .
124,531
1,441,201
48,939
Autocraft1
