Hi everybody. I've recently bought a 2001 996 that has developed a strange noise from the engine area. The sound is like a ticking or rattle. The water pump was leaking and I thought it may be something to do with that but after changing the pump the noise is still there.
It's sort of intermittent in that on tickover the noise will stop for a while and then come back. Under load it seems to get a bit louder and the frequency increases with engine revs above about 3000rpm you can't hear it but may be drowned out by the engine noise. At times the sound is almost like something rattling in time with the engine but I can't find anything loose.
I've tried a stethoscope but couldn't pin point it.
It is not affecting performance, its not burning oil.
