Very odd and specific question-
When going down the ramp at work- fairly steep 15-20% there is a sharp 90 degree left turn. If I go down in neutral covering the brakes there is a slight judder which I think is the ABS. When I do it in gear it is not an issue, but I obviously don't need to brake quite the same. I think its the inside wheel (front offside), causing the issue, but not sure why I feel that!
Anyone else noticed anything similar?
The rear offside damper has gone and I'm getting both rears replaced, but apparently front suspension all fine.
Thanks in advance!
Aidan
Thanks in advance!
Aidan
