997 : 2004- 71
996 : 1997-2005 36
Boxster : 1997- 25
pj964blue
PostPosted: Tue Jun 26, 2018 2:44 pm    Post subject: 964 Revcounter malfunction. Reply with quote
Hi
Newbie on the forum so as they say...bear with!
Rev counter on my 964 tip is up to no good!
After about 3\4 of an hours driving it suddenly dips to zero, then bumps along the bottom or even just sits there. Sometimes it shoots up again with a touch of throttle and sometimes if I give it throttle when it's sitting at about 2000rpm it actually dives DOWN to the zero again! Totally random and of course won't do it to order! The following morning back to normal!
I do have Julian Reap on the case but as it's already been through his hands to his man in Holland and six months later it's pulling the same trick he's scratching his head a bit.
Anyone else had the same or very similar problem?
Cheers.
Gazc2
PostPosted: Tue Jun 26, 2018 3:37 pm    Post subject: Reply with quote
can be a sign sign your alternator is on its way out, need to check the brushes/regulator/output
2007 997 Turbo & 924s in progress
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
pj964blue
PostPosted: Tue Jun 26, 2018 4:26 pm    Post subject: Reply with quote
Thanks Gazc2, hadn't reckoned with that!
It's going in tomorrow for a fluid change and a new belt on the distributors - far as I can see it's never been done! - so I'll get the alternator checked too.
pj964blue
PostPosted: Fri Jul 20, 2018 1:57 pm    Post subject: Reply with quote
Had it checked out at Steve Bulls earlier this week, alternator seems fine, distributor feed to revcounter fine although some slightly dodgy wiring from the dizzy has now been rectified.
After a couple of 1 hour plus trips however its stopped misbehaving! Typical but not complaining. That's cars for you!
PostPosted: Fri Jul 20, 2018 4:54 pm    Post subject: Reply with quote
I've got a mint standard rev counter 964/993 if you need a replacement. Rubicon coloured dial which you'd need to swap out for black or go for a bold colour for contrast. £150 Thumb
pj964blue
PostPosted: Sat Jul 21, 2018 6:39 am    Post subject: Reply with quote
Thanks for the offer Zingari, but not only is it a tip but with OBC as well. That part is all OK.
So for the moment still work in progress.
Thanks again.
