kas750 said:What does it read with a warm engine at tickover ?
deMort said:If it reads 0 with ignition on but engine not running
maldren said:Has it corrected it? If so, that was the problem and solution. If not.....
jimb007 said:deMort said:If it reads 0 with ignition on but engine not running
Turns out it's not reading 0 with ignition on but engine not running.
Even though I've just had the sender replaced. Is there any other way to correct this?
deMort said:Its probably the sender unit .. new or not it can read wrong .. they are pretty basic inside.
jimb007 said:deMort said:Its probably the sender unit .. new or not it can read wrong .. they are pretty basic inside.
Thanks - I'll start with this and go back to my Indy as they've just replaced the sender.
