991 : 2011-2019 0
997 : 2004-2012 0
Boxster : 1997- 22
stuarts
PostPosted: Thu Jun 14, 2018 9:57 am    Post subject: 997.1 Interior Temp Sensor Repair Reply with quote
The only fault picked up (which I knew about anyway), whe Autofarm serviced my car last week, was a malfunctioning interior temp sensor - reading too hot, so cabin blower always running cooler than should be.
I did see that someone had managed to remove and repair/replace the sponsor.
Could someone pint me in the right direction to who could help/advise?
Porschekit
PostPosted: Thu Jun 14, 2018 2:57 pm    Post subject: Reply with quote
I'm interested to hear about this since when I set my internal temp at 22 deg C and its cooler outside, it doesn't particularly blow warm air until I turn it up to 26C or more......could this be the same sensor problem?
And if so is it easily fixed? Question
997.1 C4S Meteor Grey Metalic
stuarts
PostPosted: Thu Jun 14, 2018 3:53 pm    Post subject: Reply with quote
Yep, sounds like the same symptoms, put the heater on high and it will blow hot air.
I hope it's a relatively easy fix, no dash out job!
PostPosted: Thu Jun 14, 2018 6:54 pm    Post subject: Reply with quote
ill start by saying im not sure on this , cant remember the last time i looked at a fault like this but ill say what i can ..
i thought the sensor was in the heater control panel and behind the grills there , there should be a fan behind it to draw air over it which can stop working i guess .. they do on a 996 anyways .
design 911 lists it as this part but in a different place ..
https://www.design911.co.uk/fu/prod12459/Cabin-Temperature-Sensor-Porsche-Boxster---Cayman---996---997-1H0907543A/
i think i would ( in your shoes ) remove the heater panel and have a look .. are the sensors similar .. its yours full of dust or is the fan not working .
Untill i get one in to have a play with then theres little i can say for certain im afraid.
stuarts
PostPosted: Thu Jun 14, 2018 7:06 pm    Post subject: Reply with quote
It's definitely that, Autofarm checked all flaps and fans are working.
Porschekit
PostPosted: Mon Jun 25, 2018 4:14 pm    Post subject: Reply with quote
stuarts
Did you get this part changed? was it an easy job....e.g. could the interior centre grill be taken out? It would be nice to know f I need to do mine , thanks.
John
easternjets
Watkins Glen
PostPosted: Mon Jun 25, 2018 6:01 pm    Post subject: Reply with quote
If I remember right one of my other cars had a similar issue and when they looked at the temp sensor it was chocked with fluff and crud that it had drawn in which obviously acts as a bit of a blanket so the sensor thinks it's warmer than it is. If it's any consolation my Gen 2 is exactly the same, set it at 22/23 to get what I normally get in another car at 19, if the sensor is part of the heating control unit then it should be just a case of removing it and in the first instance seeing if it can be cleaned of it's fluff.
After that I think it would have to be removed and sent off to someone for repair (winter lay up job), if it's a gen 1 you could get new heater controls if the others are worn.
On the Gen 1 it's the little grill between your two sets of buttons.
997 Turbo Gen 2
997 Turbo Tiptronic S
Porsche 968 Coupe 1992
Porsche 928 S4
Porsche 911 3.2 Carrera 1985
stuarts
PostPosted: Mon Jun 25, 2018 8:39 pm    Post subject: Reply with quote
Thanks guys,
No, not done anything yet, off to classic Le Mans and the first couple of stages of the TdF next week, it can wait as I don't think I'll be needing any heat!
Thanks for the thought about the dust & crap around the sensor, when I get back, I'm going to give that a go.
I'll report back then
v6matt
PostPosted: Wed Apr 17, 2019 3:33 pm    Post subject: Reply with quote
stuarts wrote:
Thanks guys,
Did you ever get around to fixing this? Mine has started doing it.
2008 Carrera 4 - Gen 1 997
PostPosted: Wed Apr 17, 2019 6:52 pm    Post subject: Reply with quote
The position of the interior temp sensor is in the images bellow .. ignore the seat heating only wording .
You would need a tester connected to look at the actual values for all the sensors before just condemning this one as it might not be the fault .
Either remove and a clean or try blowing through it .. you never know .. it might be filled with dust .
 Filesize:  229.45 KB
 Viewed:  764 Time(s)
 Filesize:  443.09 KB
 Viewed:  764 Time(s)
