997 : 2004- 74
Boxster : 1997- 14
Chrali
PostPosted: Wed Jun 13, 2018 11:41 pm    Post subject: What is this part by the brake fluid reservoir? Reply with quote
Can anyone please tell me what is this part by the brake fluid reservoir Question
Thanks.
Encourage alternative fuels, use all the petrol!
 Filesize:  108.65 KB
 Viewed:  1683 Time(s)
PostPosted: Fri Jun 15, 2018 6:10 pm    Post subject: Reply with quote
Thats the air quality sensor for the a/c system , it should be fitted to the plastic panel the wipers go through .. upwards of were it is atm.
The vast majority of these dont work and in the a/c system you will get a fault code saying that.
A/c will still work as normal so off hand im not sure what actual effect a working one of these has on the a/c system .
