996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
jockmog
PostPosted: Tue Jun 12, 2018 3:03 pm    Post subject: Driving with no AC Reply with quote
My 996 3.4C2 AC has a leak and, if I understand things correctly the slow speed cooling fans will not run as a result. Is it safe to drive the car in this condition until the leak can be identified and repaired? The high speed on the cooling fans operates as normal
PostPosted: Tue Jun 12, 2018 3:10 pm    Post subject: Reply with quote
Yes no problem but wear a string vest for ventilation Thumb
PostPosted: Tue Jun 12, 2018 6:56 pm    Post subject: Reply with quote
If you turn the a/c on even if its not working due to no gass the fans will still run at slow speed .. unless theres a fault with them.
On temp then low speed kicks in about 96 degrees and high speed around the 105 degrees mark .
IanG1
PostPosted: Tue Jun 12, 2018 8:32 pm    Post subject: Reply with quote
Yes low speed fans run regardless of gas in the system. If they are not working then likely the resistors. Safe to drive? Mine was like this for a while till I changed the resistors. Just make sure they fans run at full when triggered by a hot engine otherwise it will overheat and probably pop your coolant expansion tank
1998 996.1 C2 manual/LSD with aero and a big smile
JTT
PostPosted: Wed Jun 13, 2018 10:21 am    Post subject: Reply with quote
Do these low speed fans ever get noisy? My car has developed a mild "whine" sound after coming up to temp, but it goes away if I turn off the AC.
Stoo.c
PostPosted: Wed Jun 13, 2018 10:35 am    Post subject: Reply with quote
Is it definitely coming from the front as it could well be the AC compressor.
02 996 C4S
93 Skyline R33 GTS-t
91 CRX vtec turbo
01 986 Boxster S
maldren
PostPosted: Wed Jun 13, 2018 10:44 am    Post subject: Reply with quote
deleted
Mike
Sundayjumper
1999 Porsche 996 Carrera 2
PostPosted: Wed Jun 13, 2018 11:48 am    Post subject: Re: Driving with no AC Reply with quote
jockmog wrote:
Is it safe to drive the car in this condition...
The ac on my car has never worked in the 6½ years I've owned it. Engine runs fine.
maldren
PostPosted: Wed Jun 13, 2018 12:41 pm    Post subject: Reply with quote
What is there to go wrong, you have a pump that is not pumping so it is simply spinning, I guess the bearing could eventually fail but it's less likely that if you were using it.
The cooling fans are now only in use for cooling and so there is less load on them and the other AC parts are effectively passive when not in use.
Mind you, if you don;t have a sun roof it will get very hot in summer and they say this summer will be very hot.....
Mike
jockmog
PostPosted: Thu Jun 14, 2018 8:57 am    Post subject: Reply with quote
The problem is that the low-speed cooling fans are NOT running and I have a 100 mile trip to the selling dealer to get it repaired under warranty. Replacement resistors have been ordered along with a condenser replacement kit.
wasz
PostPosted: Thu Jun 14, 2018 12:41 pm    Post subject: Reply with quote
Its no problem, mine ran for ages with duff fan resistors, therfore no low speed fan before I even realised the fans were supposed to run with ac on.
I had AC fine, the fans kicked in full just fine when the coolant got hot.
My special order Vesuvious Charcoal 996 | Clutch, Fly RMS IMS AOS Job |
jockmog
PostPosted: Thu Jun 14, 2018 6:52 pm    Post subject: Reply with quote
Thanks for all the replies.
Don.
