Struggling with plenum to manifold collars
CarreraMonkey
Mugello
2 Sep 2013
2,188
Hey folks. Finally got the alternator back in, but now struggling with the rubber collars that connect the plenum to the manifolds.
The engine will fire but not tickover and I'm pretty certain its down to the rubber collars and their stupid jubilee clips not sealing.
Is there a technique or knack to getting them on flush and square? I've tried twice now and still can't get the dam thing sealed so it ticks over... :nooo:
All advice welcomed!
Yeah - hard to explain but have you read the method in the 101 projects book? It's online.
As per the image you push the rubber sleeves as far onto the inlet mainifold as possible then push in the throttle houseing and slide the sleeves over it .
Its a little bit fiddly .
Hi guys. I've managed that part ok. The concern that i have is making sure that the collars are sitting flush all the way around as the manifolds are oval and its hard to make sure they are positioned properly at the front side, which you cant see.
On top of that the jubilee clips never seem to want to sit nicely in the guide channels. They just seeme to always move around and I'm sure thats causing the leaks.
Just sounds like I have to persevere with it.
As above. It's a case of moving both rubber sleeves as far out as possible then working each side on (to the plenum) at a time, clamping the internal clip, then the other side, then the outer ones. It's all a bit left right left right whilst each position is done.
If you don't have the tb connected to the plenum you can put your hand through it to feel that all is in the right place before tightening up the clips. I found it easier this way and then just mount the tb after
Thanks all! I followed alex's method. Slid the collars back over the manifolds, then fitted to the plenum on either side first. Then to the manifolds. I suspect that one / both wasn't flush at the back and therefore not sealing.
All good now!! :thumb:
:thumbs:
Glad its all sort mate :thumb:
Excellent tip :thumb: ..
Ive done this before and may i just say when we get to Gen 2 owners doing this then this is the only way to do it :D
124,618
1,442,148
49,051
porschezilla
