996 : 1997-2005 43
Boxster : 1997- 13
Macan : 2014- 0
rob_p
PostPosted: Mon Jun 11, 2018 5:07 am    Post subject: Electric seat stopped working Reply with quote
Hi
I have the electric memory hard backed sports seats in my car.
The drivers side has stopped working - no electrical movement at all.
Passenger side works fine and I have swopped the fuses over with no difference so it's not the fuse.
Any ideas on what the next steps should be for diagnostics please?
Is this a common fault?
Rob
991.1 C2 (no mods, yet)
Jeep Grand Cherokee WK2
Ex Porsche Boxster 986
Ex Mazda MX5 mk1
-- 997 --
PostPosted: Mon Jun 11, 2018 8:51 am    Post subject: Reply with quote
I would have a look under the seat to check if any electrical plugs has worked it's way loose. Which I reckon that's what happened. But also get a multimeter nd test for voltage from the plugs. If your getting voltage and no movement despite all is plugged in then seems like the motor.. But first check plugs the test for voltage.
J
PostPosted: Mon Jun 11, 2018 6:36 pm    Post subject: Reply with quote
Assumeing you mean the electric seat wont move at all and not just the memory function then i would be inclined (as mentioned above ) to have a good look under the seat .
Main CU is at the front .
Its only 4 bolts you can then tilt the seat to gain access .. removal isnt really needed unless you want to .
rob_p
PostPosted: Tue Jun 12, 2018 5:06 am    Post subject: Reply with quote
Thanks. Demort - yes the electrics have stopped working.
I will have a look tonight.
Is there one control unit for everything or are there separate modules?
Ex Mazda MX5 mk1
PostPosted: Tue Jun 12, 2018 6:19 pm    Post subject: Reply with quote
Single unit .. big black box at the front .
Wiring diagram is spread over many pages and only lists memory / comfort but the main inputs are shown below .. fuse E1 .
 Filesize:  245.62 KB
 Viewed:  651 Time(s)
rob_p
PostPosted: Tue Jun 12, 2018 7:43 pm    Post subject: Reply with quote
All fixed!
Unplugged it and plugged it in again - all sorted.
Feeling a bit of a fraud but thanks for the pointers.
Ex Mazda MX5 mk1
PostPosted: Wed Jun 13, 2018 7:12 pm    Post subject: Reply with quote
Thats the eqivelent of turning the computer off then back on .. a Hard reset .. fixes a lot of things to be honest .. these cars have about 20 computers im afraid .
vehicle handover also does it and is done with a tester .
Its fixed Thumb
