964 : 1989-1993 6
Boxster : 1997- 18
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
Chrali
PostPosted: Sun Jun 10, 2018 8:15 pm    Post subject: Cleaning behind the wheel arch liners Reply with quote
I took off the wheel arch liners to check if the drainage bungs had been removed, but found an unexpected problem. Lots of mud! There is some minor surface corrosion, so I think its been found in time. Look at the state of the inter-coolers; pretty blocked. The front wing corners seem to be a mud trap as well, but as its plastic its just an annoyance.
It took me hours cleaning the mud out and after all of that I realised that I'd still forgotten to check the drainage bungs Sad I'll do it when I rust convert and under seal the arches.
Encourage alternative fuels, use all the petrol!
Front intercooler
 Filesize:  587.41 KB
 Viewed:  1434 Time(s)
Rear wheel arch
 Filesize:  819.03 KB
Front wheel arch
 Filesize:  930.89 KB
Chrali
PostPosted: Sun Jun 10, 2018 8:21 pm    Post subject: Reply with quote
After lots of cleaning ! I know this is minor stuff, time consuming though and I'm happier knowing its better than it was.
Intercooler
 Filesize:  712.71 KB
 Viewed:  1421 Time(s)
Rear arch
 Filesize:  716.34 KB
Front arch
 Filesize:  731.6 KB
SD99
PostPosted: Sun Jun 10, 2018 8:43 pm    Post subject: Reply with quote
Nice work Thumb
Might have to do the same as some point.
Tobyone
PostPosted: Sun Jun 10, 2018 9:31 pm    Post subject: Reply with quote
A really satisfying result.
Bit like you I get great pleasure from finding something like that and making it all nice.
Good work fella
997.1 C4s GT Silver, factory Aerokit
