996 : 1997-2005 43
Boxster : 1997- 12
Macan : 2014- 0
easttorks964cab
PostPosted: Sun Jun 10, 2018 12:33 pm    Post subject: oil leak, your opinions please ** NOW WITH PICS** Reply with quote
Hi Guys,
ive owned my 1998 996 for 6 years. up to now, it has not had any signs of oil leaks. On its last service, they flagged up a slight leak.
The leak is directly under the engine, around 2 ft from the rear end.
When driven, there are spots of oil deposited on the rear bumper.
Once parked up, I have shoved cardboard underneath and there are drips immediately(in the same place, not in various spots)
When left overnight, there doesn't seem to be much more oil on the card (ie it seems it isn't leaking once its stood)
The engine bay itself is dry of oil.
could you give me any ideas what you think may be the culprit.
A friend had a similar problem, turned out to be the sump seal. Is this likely?
Cheers in advance
Chris
Last edited by easttorks964cab on Sun Jun 10, 2018 1:43 pm; edited 2 times in total
 Filesize:  56.47 KB
 Viewed:  1373 Time(s)
 Filesize:  60.14 KB
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Sun Jun 10, 2018 1:36 pm    Post subject: Reply with quote
Any chance of a photo so that us less educated than DeMort might get a chance to offer assistance.
easttorks964cab
PostPosted: Sun Jun 10, 2018 1:39 pm    Post subject: Reply with quote
thanks, just updated with pics.....thanks for your reply
MisterCorn
PostPosted: Sun Jun 10, 2018 1:44 pm    Post subject: Reply with quote
It does look like sump. I would give it a really good clean and then see if it easier to locate. It has clearly spread a lot.
Nipper620
PostPosted: Tue Jun 12, 2018 4:35 pm    Post subject: Reply with quote
Looks like it’s around the sump drain, did they put a new washer on during the service.
rdodger
PostPosted: Tue Jun 12, 2018 5:03 pm    Post subject: Reply with quote
I would go with RMS as it looks like the leak is at the back of the engine/front of car and tracking along the sump.
As said before it needs a good clean then you might stand a chance of seeing where i's coming from.
coullstar
PostPosted: Tue Jun 12, 2018 5:12 pm    Post subject: Reply with quote
It is in that area between gearbox and engine mating area.
2000 Audi B5 RS4
wasz
1999 Porsche 996 Carrera 2
PostPosted: Tue Jun 12, 2018 8:16 pm    Post subject: Reply with quote
I'd say RMS or the IMS end cover.
Mine was the IMS end cover.
It leaks from between the engine and box and oil travels backwards as you drive.
Sounds like its on the verge of dripping enough to warrant the box out.
My special order Vesuvious Charcoal 996 | Clutch, Fly RMS IMS AOS Job |
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Tue Jun 12, 2018 9:52 pm    Post subject: Reply with quote
^^^This^^^
easttorks964cab
PostPosted: Thu Jun 21, 2018 6:57 am    Post subject: Reply with quote
UPDATE.
The leak is solved and repaired. It was a failed cam tensioner seal. £130 all-in, so one of the cheaper fixes!
Thanks for your attention guys.
Martin996RSR
PostPosted: Thu Jun 21, 2018 7:05 am    Post subject: Reply with quote
Thanks for coming back with the diagnosis. I have a moist patch in the same area on my engine, can you tell me what was involved in the repair? Can you just undo the tensioner and remove it and replace the seal, or do you need to lock the cams first?
easttorks964cab
PostPosted: Thu Jun 21, 2018 11:02 am    Post subject: Reply with quote
Hi Martin,
my mechanic did the job, so I cant help on that front unfortunately.
it was 1.5hr job, a seal and oil top-up £130.00
I hope you get yours sorted. mine started as a damp oily patch, but quickly became a drip.
chris
wasz
PostPosted: Thu Jun 21, 2018 11:10 am    Post subject: Reply with quote
I would lock the cams before removing the tensioner.
Move to tdc then 8mm drill bit to secure crank
flick out cam end plug and check slot alignment.
insert cam lock tool.
You need the right tool for your 3 or 5 chain engine. I made one for mine- see my clutch / fly / imsb cover thread in sig
