997 : 2004- 77
996 : 1997-2005 39
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 12
wilsonny
PostPosted: Thu Jun 07, 2018 9:21 pm    Post subject: garage lift Reply with quote
just about to buy myself a new lift of some sort for my garage when working on the 993. I had been thinking of going for a mid rise scissor lift but I'm wondering how much access is blocked by one of these and have started to rethink and considering either the ezcarlift or the quickjack which both just fit under the sills (largely).
has anyone got any experience of these or any other recommendations ?
I can't accommodate a post lift as I'm working in a single domestic garage.
1996 C2 manual
hopeydaze
PostPosted: Fri Jun 08, 2018 6:55 am    Post subject: Reply with quote
I can't help you, however please let us know what you decide because I'm also thinking about a scissor lift.
Th team at Center Gravity told me to buy one - probably so I can clean the underside properly which will make their job easier.
Roro
PostPosted: Fri Jun 08, 2018 7:26 am    Post subject: Reply with quote
I was looking at one of these a while back but got distracted by other household purchases, might still go for one at some point
https://www.automotechservices.co.uk/products/as-7630-mobile-scissor-lift/
2007 997.1 GT3
2017 F87 M2
MaxA
PostPosted: Fri Jun 08, 2018 8:03 am    Post subject: Reply with quote
I'm getting a Quicklift when my garage gets redone over the summer. It meets my needs which are just basic, wheel changes, etc.
2010 9972 C4S PDK: Carrara White, Sea Blue. Mostly driven, lightly modified, occasionally tracked, and usually a bit grubby.
cableguy
PostPosted: Fri Jun 08, 2018 8:50 am    Post subject: Reply with quote
I've also been looking at this one which looks cracking value compared to most others.
Quite a few of the lower priced units including the QuickJack need a seperate air tank/supply whereas this unit does not.
A couple of threads here that may be of use:
http://911uk.com/viewtopic.php?t=125532
http://www.911uk.com/viewtopic.php?p=897829
http://www.911uk.com/viewtopic.php?t=122245
C.
Pork!
peterg1955
PostPosted: Fri Jun 08, 2018 9:09 am    Post subject: Reply with quote
C.
there's a 'supply/tank unit' thing in the third picture (top left) in the photos for that lift so I think you'll find it exactly like all the others...
2002 996 C2 black/black with aerokit and M030
cableguy
PostPosted: Fri Jun 08, 2018 9:15 am    Post subject: Reply with quote
Not with you Peter?
The pics and description are as follows:
£995.00
This compact mobile scissor lift is ideal for tyre and body shops. A great favorite with DIY and classic car enthusiasts.
Features
• Lifting capacity 2.7T
• Lifting height 1300mm
• Minimum height 118mm
• 240v single phase
• No installation required
• No air supply required
C.
Pork!
wilsonny
PostPosted: Fri Jun 08, 2018 9:16 am    Post subject: Reply with quote
The mid-rise scissor lifts are all quite similar, except that some like the ones sjr supply (http://www.sjrgarageequipment.co.uk/scissor-car-lifts/) are designed without end bars on the lifting frame, so in theory they make access a bit easier.
I've also been looking at the next level up from the scissor lifts (http://sm-t.co.uk/product-category/vehicle-lifts/mobile-lifts/) which leave the centre section clear.
However my dilemma is that both of these lifts are big and heavy and pretty much will need to stay in place, probably channeled into the garage floor if I want to be able to roll the car in an out manually (which I do).
This is why I've ended up thinking more about the EZcarlift and QuickJack which are light and removable. As far as I can see, the ezcarlift (http://blog.holden.co.uk/order-your-ezcarlift-now/) goes up higher and goes up without horizontal movement. However it's more expensive. Quickjack (https://www.quickjack.com/) comes with all the hydraulics etc, goes up quick, not as high, but it does involve some horizontal movement, so that's going to need some faffing when working in a small domestic garage.
Quickjack is significantly cheaper that ezcarlift though and their marketing is a lot more "slick" if that means anything of course.
I've seen both these with a 993 on, so I know both CAN work quite well, but still can't decide which way to go at the moment.
1996 C2 manual
peterg1955
PostPosted: Fri Jun 08, 2018 9:29 am    Post subject: Reply with quote
cableguy wrote:
Not with you Peter?
£995.00
Features
• 240v single phase
C.
ah sorry for the confusion, I was commenting in relation to "Quite a few of the lower priced units including the QuickJack need a seperate air tank/supply"
I have a Quickjack and it doesn't have/need an air supply as it's hydraulic and the motor/tank is a small unit that's easily carried to wherever you need to lift the car..
jev911uk
PostPosted: Fri Jun 08, 2018 9:33 am    Post subject: Reply with quote
I spent quite a bit of time looking at all the lift options and settled on this version:
https://www.automotechservices.co.uk/products/as-7532b-3-2t-mid-rise-scissor-lift/
The weight capacity is quite higher than I would ever need but that means its nice and sturdy so swinging on breaker bars under the car feels as safe as it ever could. The separate bases (only linked by hydraulic hoses) means you have some flexibility in the spacing and there is nothing to get in the way when dropping an engine etc.
In use:
PostPosted: Fri Jun 08, 2018 9:42 am    Post subject: Reply with quote
What an amazing picture worship
cableguy
PostPosted: Fri Jun 08, 2018 9:49 am    Post subject: Reply with quote
Thanks for clarification Peter. Thumb
Great info Jev and that's an awesome pic. Must have taken a while to stage.
Wink
C.
Pork!
Endoman
PostPosted: Fri Jun 08, 2018 11:49 am    Post subject: Reply with quote
I'm in the same boat but with a bit more flexibility as the garage is huge.
The garage floor may not be up to a 2 poster but I don't want to clutter the space with a scissor jack. I'm looking at a recessed system like:-AS-7532B 3.2T Mid Rise Scissor Lift but the Ezyjack looks interesting. Will it lift high enough for an engine drop?
Kat1
PostPosted: Fri Jun 08, 2018 1:24 pm    Post subject: Reply with quote
Some more input from elsewhere on this forum.
http://911uk.com/viewtopic.php?t=125532&postdays=0&postorder=asc&start=0
SGH
2010 Porsche 997 Carrera 4S
PostPosted: Fri Jun 08, 2018 3:15 pm    Post subject: Reply with quote
I have been looking for a while now and the Quickjack looks like a winner for me, I can use in my garage or out on my drive for cleaning.
Porsche 997.2 Carrera 4S - Carrara White / Cocoa
Defender 300Tdi 110 HCP - Keswick Green
Connect L2 Double Cab - Moondust Silver
VW California Ocean 150PS DSG - Reflex Silver
eagle
PostPosted: Fri Jun 08, 2018 3:49 pm    Post subject: Reply with quote
944S
911SC
911 3.2
993 C4S
Boxster S
996 GT3 mk2 CS
991 GT3 RS
991.2 GT3. Current
If you have a slab thickness of 250 mm plus , then you could do this. Around £1400 from Twinbusch .
 Filesize:  1.76 MB
 Viewed:  3928 Time(s)
Endoman
PostPosted: Fri Jun 08, 2018 5:06 pm    Post subject: Reply with quote
My garage is an old cow shippon. I'll have to do a bit of test drilling to establish the slab depth but I doubt it's anywhere near 250mm and the quality of the concrete unknown. I can get a short 2 poster which supposedly would be ok with a slab depth of 150mm and the posts are moveable. It will lift to 1.5 metres
http://www.sjrgarageequipment.co.uk/2-post-lifts/
Looks like a bit of digging out and relaying will be required whatever I choose. You never know the old slurry channel may have been filled with concrete or perhaps the cow ***** was just skimmed over.
wilsonny
PostPosted: Fri Jun 08, 2018 5:38 pm    Post subject: Reply with quote
another part of my thinking is to question how much lift height I need. if I'm working under the car, presuming I can't go high enough to stand up (garage wouldn't accommodate that) then most of the time I want the car at a comfortable height when lying on a creeper. so the portable lifts can do this and it's what I've had up until now with my MR1 lifting ramps. it's always going to be handy to go up a bit if tackling the engine coming out of course. i think ezcarlift looks like it might go high enough for engine removal at a pinch.
1996 C2 manual
Endoman
PostPosted: Fri Jun 08, 2018 6:42 pm    Post subject: Reply with quote
Height of engine is approx 65cm + engine jack or whatever. Removing rear PU will give more room. So I reckon around 90 cm lift unless you remove the inlet manifold. Perhaps less.
PS. TwinBusch site very useful and good prices considering made in Germany.
wilsonny
PostPosted: Fri Jun 08, 2018 9:28 pm    Post subject: Reply with quote
so looks like neither quickjack(21 inch lift) nor ezcarlift(26 inch) would allow you to get the engine out cleanly... might be able to drop and then workaround a solution I suppose.
1996 C2 manual
