997 : 2004- 74
Boxster : 1997- 14
g911omr
PostPosted: Wed Jun 06, 2018 12:40 pm    Post subject: Speaker upgrade Reply with quote
I'm looking to improve the speakers in my 996.1 C2.
Currently there are dash mounted, 1 in each door and the rear speakers. I'm assuming that they are standard original items.
The head unit is Alpine along with a separate amp under the bonnet care of the PO.
Sound is ok, but just a bit average.
Any ideas on the best way to go? Possibly starting with the door speakers.
Cheers all.
Mark
Halcyon
PostPosted: Wed Jun 06, 2018 1:55 pm    Post subject: Reply with quote
the door speakers are actually good quality, but you have to send the right frequency range to them (they are woofers, not subs) If they are driven by a dedicated amp, set it to LF/LPF for low frequency.
Dash and rear speakers - Alpine SPG-10C2 is a popular upgrade - you will have to do some work to get them to fit (or indeed any replacement speaker) Or Hertz if you're feeling flush.
Then add a slimline sub under the passenger seat (as there's nowhere else to put one.)
Sorted!
996.2 Carrera 4 Convertible Tip
Grey996
PostPosted: Wed Jun 06, 2018 2:01 pm    Post subject: Reply with quote
I replaced my speakers with Alpine ones, you’re limited for choice due to the tight space in the dash. Can’t remember the model but a search on here should show plenty of posts.
2002 Porsche 996 C2
Grey996
PostPosted: Wed Jun 06, 2018 2:04 pm    Post subject: Reply with quote
There’s a good video on YouTube too about cutting the carrier to fit your new dash speakers
2002 Porsche 996 C2
g911omr
PostPosted: Wed Jun 06, 2018 2:18 pm    Post subject: Reply with quote
The amp is 4 channel so as it stands, 2 channels power the dash and door speakers and 2 channels power the back speakers. Is there any benefit in replacing the doors with Bose?
Tim_996
PostPosted: Wed Jun 06, 2018 2:49 pm    Post subject: Speaker upgrade Reply with quote
I'm thinking of doing the same, have a look here, straight swap I believe and a popular choice:
http://www.jmgshop.com/9xx---porsche-boxster--996-dashboard-speaker-upgrade-kit-with-alpine-speakers-62-p.asp
snb993
PostPosted: Wed Jun 06, 2018 3:19 pm    Post subject: Reply with quote
I changed mine to the Alpines mentioned above and in the JMG link for both the dashboard and rear speakers. Yes they sound better / fuller than the originals (mine had the Bose system FWIW which isn't a lot IMHO!). They are only 4" ish in size and not in a great place so don't expect much bass just a better quality sound over the originals
A worthwhile upgrade i think as they aren't very expensive
The biggest improvement was ditching the the totally cr@p CDR-23 head unit and replacing it with the AVIC F20BT and a Pioneer amp which sits neatly under the plastic cowling in the frunk. These now power all of the speakers plus the original Bose sub which my son opened up and lined with Dynamat and loose fill fibre and have made a huge difference. Very effective and cheap upgrade IMO
He also Dynamatted/filled behind the rear speakers as the backing is pretty flimsy
The only speakers that are original in mine are those inside the Bose sub unit and the Bose door speakers which are probabaly the weakest link now and next to be replaced
It won't win any competitions but is a 1000% better than original!
HTH
thumbsup
The Bose system in a 996T really wasn't their finest hour - but that's ok as the engine was Very Happy
996T - Cobalt blue, K24's, GT2 I/C's, Techart SSK, Manthey KWv3, H&R ARB's, RS engine mounts, Europipe, GT3RS 6 pots, 997T discs/RS29's all round etc
964 C4 - GP white, 993 C4 gearbox/front diff, Wayne remap, Bilstein B6's / H&R springs, polybushed, Cup 1's, RS SSK, gutted cat etc
993C4 - sold
928S4 - sold
eabeukes
1999 Porsche 996 Carrera 2
PostPosted: Thu Jun 07, 2018 8:27 pm    Post subject: Reply with quote
I am in the process of swapping out all 4 upper speakers from the old Nokia ones to Hertz DCX 100.3's. O chose these as they give a much broader frequency response compared to the Alpines and others. Theyre also made by the same people who make Audison (and are pretty much the same thing Very Happy ) but for less money.
The kit suggested is great but *very* expensive. The Hertz are not a perfect fit however, and you'll also want to get some VM speaker connectors.
I am not (yet) swapping head unit, amp or door woofers as they are still good enough.
I'll post photos soon of the process if you are patient, or feel free ot DM me with questions.
sp1ke
PostPosted: Sun Oct 14, 2018 10:28 am    Post subject: Reply with quote
I wasn't sure where best to post this, so thought I'd reply to this old thread for anyone else who stumbles across it.
Hope this helps anyone else looking for a cheaper alternative to the JMG kit.
I bought:
2 sets of the Alpine speakers from Amazon (£39-45 per pair)
https://www.amazon.co.uk/gp/product/B002XCNPMS/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
1 set of JMG spacers & cables.
https://www.jmgshop.com/9xx---dashboard-speaker-fitting-kit-without-speakers-355-p.asp
I appreciate JMG will have had some R&D costs to recover, but having seen what you get for your money, I couldn't bring myself to pay the asking price for a 2nd set.
After a little hunting around I found adaptor leads on Amazon for under £2
https://www.amazon.co.uk/gp/product/B01KQG3MK2/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
These seem slightly better quality than the JMG ones, as they have thicker gauge cables & the plastic connector was a better fit. The Amazon ad doesn't list Porsche for compatibility, but I can confirm they are a perfect fit.
I made up a 2nd set of spacers with the help of some Thermomorph (£16)
https://www.amazon.co.uk/ThermoMorph-Moldable-Reheatable-Reusable-Remoldable/dp/B00D3LAZ9O/ref=lp_4057927031_1_1?srs=4057927031&ie=UTF8&qid=1539511322&sr=8-1
1 tub of Thermomorph would probably be enough for 2 sets of spacers, so for £20 you could get a tub & 2 sets of leads which should be enough to upgrade both front & rear speakers.
PostPosted: Sun Oct 14, 2018 10:43 am    Post subject: Reply with quote
Never heard of Thermomorph but a quick search and it looks like very handy stuff that has loats of uses Thumb thats todays lesson for me Thumb
maldren
Isn't there a danger that the ThermoMorph will deform on a hot day?
Mike
sp1ke
PostPosted: Sun Oct 14, 2018 11:05 am    Post subject: Reply with quote
I don't think so, they advise you need to immerse it in water boiled to 150degrees to mould it. Having said that I just boiled the kettle. It probably wasn't 150, but did the job & they've been in the car for several weeks now.
Having said that I probably wouldn't use it in a hot engine bay or for safety critical components.
Like Sugru it does seem to have many uses. Sugru once cured has a more rubbery/soft texture, by contrast Thermomorph is rock hard.
Dammit
Watkins Glen
PostPosted: Sun Oct 14, 2018 12:14 pm    Post subject: Reply with quote
Were you down a deep mine?
asterix_the_gaul
PostPosted: Sun Oct 14, 2018 2:44 pm    Post subject: Reply with quote
That would have to be a pretty deep mine! The deepest mines only add about 5deg or that sort of order of magnitude, you're better off with a pressure cooker, you'd get 120 no problem. Think it must be farenheit, but 150 is only 62c so reference boiling is a bit odd..
sp1ke
PostPosted: Sun Oct 14, 2018 3:05 pm    Post subject: Reply with quote
My mistake... I hadn't spotted the "f" suffix after the reference to 150 degrees in the manufacturers instructions.
Marky911
PostPosted: Sun Oct 14, 2018 5:01 pm    Post subject: Reply with quote
Slight thread hijack here but pretty relevant...
Does the Favtory CD-R-22 have preouts/RCA's to supply a signal to an amp?
If not is there a way to do it?
I'm happy with my cdr22 and I use a cigarette lighter Bluetooth dongle to steam my iPhone music to it. I do however want to swap my dash and rear quarter 4" speakers (no door speakers in mine) and add an active amplified all in one slimline sub thing.
Can I do this and keep my CD-R-22?
Has anyone done it and can recommend the pre-amped sub?
Cheers. Thumb
PS. I never usually bother with audio in a 911 and just wear my iPod on long motorway slogs but we are off to Europe possibly twice next year so I want some music. Wink
Halcyon
PostPosted: Sun Oct 14, 2018 9:03 pm    Post subject: Reply with quote
The CD-R-22 does not have preouts/RCA
but.
Most amps can use speaker level inputs, so you don't need RCA jacks..
BUT!!!
The wiring in the 996 uses a common ground for the speaker wires. which most amps won't like...
Check the amp's specification before buying Thumb
(or install a new 8 wire speaker loom)
Dammit
Watkins Glen
PostPosted: Sun Oct 14, 2018 9:26 pm    Post subject: Reply with quote
Would that common ground be why having a charger in the lighter socket makes a "shurf/shurf/shurf" noise come through the speakers sometimes?
Marky911
PostPosted: Sun Oct 14, 2018 9:53 pm    Post subject: Reply with quote
Thanks Halycon, sounds like hassle. I'll swap the 4 speakers for good stuff first then weigh up the sub. Nothing's ever easy with these is it? I thought I'd get off lightly being pre-MOST. Grin
maldren
PostPosted: Mon Oct 15, 2018 7:50 am    Post subject: Reply with quote
150°F (66°C) isn't very hot although probably ideal for moulding where you might touch it. I would worry that it might deform on a hot day abroad with outside temps hitting 40°C and dash temps being quite a bit higher.
Sounds like a useful material though and I do plan to try it for other applications.
Mike
Goto page 1, 2, 3 ... 9, 10, 11  Next
Page 1 of 11
