When I switch the AC on with the engine running the cooling fans don't appear to come on. The fans will come on when the coolant temperature reaches the trigger point. I have tested all the relays and all of them seem to operate. How can I tell if the AC Compressor clutch is engaging and where is the electrical connection for the compressor? My Bentley manual says that it is on the left side of the engine compartment - a big help! The air from the AC system is not cold.
I have also searched for an article on how to use the OBC to get actual coolant temperature readings which I came across before but haven't been able to find it. Can anyone post a link, please?
Thanks,
Don.
Thanks,
Don.
