Sports exhaust not working
ian_alex
25 May 2015
235
I have the "adjustable noise" system which is operated by the electro/ vacuum system moving the bypass flaps.
I have in the past removed the levers and freed them up and all has been working well for some time, however when I went for a run yesterday no change in exhaust noise when I push the switch.
A look underneath confirms that nothing moves when the switch is pressed.
The levers are free and all vacuum pipes look good (as far as I can see) so I'm fairly sure its the electrical part of the system. All connections are fine but car electrics are not my strongest point. I can't find any reference to a fuse, is there one?
All assistance appreciated!
Many thanks.
Most likely to be vacuum, might be mechanical, unlikely to be electrical.
Test and prove the vacuum bit first.
124,605
1,442,018
49,038
DD77
