Poor DAB reception solved
TobesEtc
Mexico City
2 Jun 2014
1,851
The DAB reception in my car has always been poor. A while ago I got Sylwester at Enigma audio to fit the same DAB aerial as works perfectly in Mrs MR2. Still no joy. As I usually listen to Spotify I forgot about it for a while but this week asked Sylwester to see if he could sort it out.
Turns out that the USB adapter for my wireless phone charger was causing the issue (similar to one that plugs into a cigarette lighter but actually rooted in behind the dash in my car). It was an iOttie that came with a fairly expensive wireless cradle (we first suspected the wireless charger itself but soon proved that wasn't at fault).
We replaced with a new Belkin version and everything suddenly works fine - hundreds of DAB stations.
So... If your DAB isn't working and you have a USB power adapter in the car (who doesn't these days if you charge you phone!) try removing it. NB the DAB might take a minute to reacquire the signal after the source of interference is removed so be patient.
I have the Continental radio fitted & have been using my phone as a dash cam. As it eats battery I plug it into the cigarette lighter, destroys DAB. Started using a plastic connector as oppose to the metal power monkey one & it's better but still not great. Bit of an issue as I'll soon buy a proper dashcam.
Hi, could you let me know which Belkin one you've bought (+ if single or dual)?
I've bought a dedicated dashcam now and it has the same issue, the joke is if you plug into the USB port on the Continental it still cuts DAB totally too!
I'll ask - it's embedded behind the dash.
Did you manage to find out which cigarette adapter you've got?
I've tried both a griffin and belkin ones with the same issue unfortunately, though it might be that a specific one is required.
Sorry, don't know which model number it is! I've got picture, but you can hardly see anything. I've attached it just in case it helps...
So, I've tried various USB chargers and even some ferrite core clamp filters, all to no avail, any other suggestions :?:
If you are in range of West London, call Sylwester at Enigma Audio. He'll be able to fix it.
124,591
1,441,880
49,022
emb01
