991 : 2011- 19
997 : 2004- 74
996 : 1997-2005 33
993 : 1993-1998 7
Boxster : 1997- 33
Cayman : 2005- 20
searider
PostPosted: Tue May 29, 2018 12:01 pm    Post subject: Changing sunroof seal? Reply with quote
How simple / difficult is it to change the external sunroof seal?
Mine is looking a bit old and hardened and could do with refreshing.
Usual progression - 205 1.9 / Corrado VR6 / Audi B5 S4 / RS4 / 996 C2 Coupe.
PostPosted: Tue May 29, 2018 6:12 pm    Post subject: Reply with quote
If you download Body External from here ..
http://911uk.com/viewtopic.php?t=83491
Youll find instructions on how to remove the sunroof .. its then just a matter of fitting the new seal around it .
Not a hard job but the new seal is often tight to close so best left in the closed postion for a few days after replacement to squash it a bit Smile
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Tue May 29, 2018 6:38 pm    Post subject: Reply with quote
I just removed the sunroof on my car last week. It really is a piece of cake.
searider
PostPosted: Wed May 30, 2018 8:43 pm    Post subject: Reply with quote
Thanks all,
Just discovered that the sunroof now won't slide back......
PostPosted: Thu May 31, 2018 7:14 pm    Post subject: Reply with quote
If you remove the interior light consol you should have access to the motor , there is an emergency operation to move it which should be listed in the owners manual ... it would be usefull to know if it moves that way .
Does the roof motor make a noise as though its trying to work ? if so something jamming it or seized .. if not then a fuse .. switch fault perhaps .
searider
PostPosted: Thu May 31, 2018 8:02 pm    Post subject: Reply with quote
It goes up and down.
Clicks a bit.
I think something might be jammed 🙁
996driver
PostPosted: Mon Aug 12, 2019 12:38 pm    Post subject: Reply with quote
I know this is an old thread but I thought I'd missed something when I was reading it so I'm not sure if there are different 996 sunroof variations.
My 1998 C2 has the seal on the body side not on the sunroof itself so I couldn't see the requirement to remove the sunroof to replace it.
By retracting the sunroof into the car I've managed to remove the seal using a trim removal tool but there was some corrosion underneath that I'm now treating before refitting the new seal. The job wasn't too bad but I'd definitely recommend some sheets inside the car to catch any rubbish that drops from the seal as you remove it.
I'll do a video on the steps I used once I've got the job completed
https://porsche911owner.blogspot.com/2019/08/porsche-996-sunroof-seal-replacement.html
1998 911 Carerra 2 Manual Coupe in blue
Previously :
1986 944 2.5 Lux
2001 911 Carrera 2 Manual Coupe in silver
P0tential
PostPosted: Wed Aug 14, 2019 9:12 am    Post subject: Reply with quote
Did yours quiet down at all with the new seal? What did you use to treat the corrosion?
I adjusted my sunroof last night and noticed that the seal is not looking too good, so I will need to change it this summer.
996 Carrera 4 Coupe
996driver
PostPosted: Wed Aug 14, 2019 12:00 pm    Post subject: Reply with quote
I've not yet driven it at speed to check but it certainly looks to have filled the gaps that were there before.
For the corrosion I cleaned it up and then use Dynax S50 to spray on to protect and hopefully prevent further rusting.
Previously :
1986 944 2.5 Lux
