Well, I finally got around to replacing my PCM 2.1 with a lovely Pioneer AVIC over this nice long bank holiday weekend. In general, with use of a Connects2 kit for my Bose, steering wheel control and fascia, it all went really well. Routing the satnav cable through the grommet behind the battery was a pain in the ... back ... but the only problem I have is that I can't get the FM/AM aerial to work at all!
I've used a powered facra to ISO adaptor, made sure the adaptor's getting 12v from the antenna/amp trigger, but nothing happens - makes no difference if it's connected to the facra cable or not.
Any hints/tricks other problems people have had - I knew it wouldn't work without the powered adaptor, but just expected to plug that in and for it to work, but no joy. I tried plugging the old PCM back in, and that works fine, and got a replacement adaptor today, just in case, but no joy there either. Any clues - at a bit of a loss.....
ta
pete S
ta
pete S
