997 battery lead problem.help needed
Jonnywise
7 Aug 2016
89
Went to start her up and it clicked like a flat battery
Tried again and total dead.it happen a couple of months ago and I wiggled the positive lead on the battery and it started and run fine until now.the connection is dead tight on the battery and the battery is only 2 months old.
Do you think there could be damage on the lead somewhere ?
Cheers Jonny
I`m sure DeMort will be along shortly but I seem to remember something about a connection alongside the battery somewhere in the scuttle area .. a negative maybe ? The answer was to clean the connection.
Post i made about replacing the power box pin here ..
http://911uk.com/viewtopic.php?t=118716&highlight=power+dist
First check is a voltmeter on the battery .. if you have 12 volts then the battery is fine so that leaves either an earth lead fault or this power box pin .
Wiggleing the power lead and its the far end away from the battery you want to move .. if it starts after that then that kinda proves you need a new pin and lead .
If the click was from the engine and you have dash lights / headlights all working then that kinda points to a starter motor or a power lead to it being at fault .
997
Yes started when I wiggled the lead again
Were is the best place to buy the parts design 911?
Jonny
They are OPC only parts as far as im aware .. have a good read of the instructions in that link before doing it yourself and also to make sure that pin is heavily corroded and hence is the fault.
997
Cheers dermot
Not a bit of me doing it my self il take it to a local garage
Cheers Jonny
124,590
1,441,852
49,021
Camarocane
