996 : 1997-2005 42
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
Shanghai
PostPosted: Sun Sep 09, 2018 9:17 am    Post subject: Reply with quote
Perfect on the Merc, slightly firmer pressure when stopped and off it goes. Cracking feature, power steering also stays active. Also stays off and doesn’t do the annoying starting itself back up
991 C2S X51 powerkit PDK in racing yellow, PCCB, PDCC, PSE, Sports design kit, ducktail.
EX 997.2 Carrera 4S PDK
EX 997.2 Carrera S PDK
EX 997 C2 gen 2 PDK
EX 993 Targa
EX 993 Carrera 4 manual
EX 996 3.4 Cabriolet
PostPosted: Sat Oct 06, 2018 4:48 pm    Post subject: Reply with quote
Some info i found on it ..
The Auto Start Stop function is not available in the
following situations, for example:
• When Sport mode is activated.
• When PSM is switched off.
• During manoeuvring.
• When AC MAX mode is activated.
• When the “Windshield defrost” function is active.
• At elevations above approx. 9850 ft (3,000 meters).
• After engaging a gear without pressing the clutch pedal
when the engine is automatically stopped.
The Auto Start Stop function is available with limited
functionality in the following situations, for example:
• If the air conditioning or passenger compartment
heating is operated at a high setting or if the defrost
function is running for long periods of time.
• If the charge state of the battery is low.
• On uphill or downhill gradients.
• When vehicle internal test processes are taking place,
for example automatic engine diagnosis.
• In the case of excessively low exterior or battery
temperature.
Goto page Previous  1, 2
Page 2 of 2
