991 : 2011- 19
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
Cy00
PostPosted: Sun May 27, 2018 10:06 am    Post subject: Reply with quote
well executed mods. good job.
Just a query on the seats, do the current seats have side airbags? if not, how did you get rid of the airbag warning light?
Magic919
PostPosted: Sun May 27, 2018 10:21 am    Post subject: Reply with quote
Easy option is to code them out.
997.2 C4S PDK
MaxA
PostPosted: Thu May 31, 2018 8:40 am    Post subject: Reply with quote
Good to finally see this car on this forum now. MINI+997 FTW.
We'd all still want to learn about the catastrophic engine failure though. Dont know
OllyW
PostPosted: Sat Jun 02, 2018 8:34 am    Post subject: Reply with quote
From what Hartech have said, there was major internal failure. It could have been rebuilt, but the money wasn't a million miles away from a full new motor with a 2 year Porsche warranty. My head told me to go that route.
It's my pride and joy and wouldn't do anything unless it was done properly. The new engine feels great and I'm more than happy knowing it's brand new and under warranty with Porsche. 750 miles done so far, just looking forward to hitting 1000 so I can get it back to Hartech for a check over, oil change, and then start to open it up a little bit more.
Jamie_c
PostPosted: Sat Jun 02, 2018 2:07 pm    Post subject: Reply with quote
Nice work! Its good to see a bit of tasteful modding to a 997.
I've been considering a set of those seats for ages but haven't pulled the trigger yet, too worried they might be uncomfortable and make it difficult getting access into the rear with the fixed backs.
997.2 Carrera 4S, Basalt Black, Sand Beige, SharkWerks Bypass, 20" Satin Platinum Carrera S III Wheels
OllyW
PostPosted: Sat Jun 02, 2018 3:11 pm    Post subject: Reply with quote
I see you're in Leeds, not too far away. You're more than welcome to try them if you're passing Teesside.
With them all the way forward on the runners it is a seriously tight squeeze to get in the back. I've taken my rear seats out anyway but was curious to see if it's possible. I'd say realistically not, unless the seat was mounted to the runners slightly further forward so that in it's forwardmost position, it may be possible for kids to squeeze behind.
PostPosted: Sat Jun 02, 2018 3:28 pm    Post subject: Reply with quote
you guys removing your rear seats , did you know there is a rear seatbelt delete kit available ,to tidy up the holes the belts go through
https://www.suncoastparts.com/product/997RSD.html
weebz
PostPosted: Sat Jun 02, 2018 5:31 pm    Post subject: Reply with quote
Conrod, cylinder crack, valves, cam chain, oil starvation? or just a catashtropic engine failure Dont know
Nice to know you have a new engine though, and if the cost implication was negligiable then nice to have the engine warrantied from Porsche, how's that work with not having a OPC warranty on a modified car?
Like others I prefered the other wheels, but also like the BBS, would love to run mine lower but with the crappy roads and speed bumps around here not really doable.
Seats look awesome too Thumb
2010 Basalt Black 997 Carrera S - 'J-Lo 2'
2004 Atlas Grey 996 C4S - 'J-Lo' (sold)
OllyW
PostPosted: Mon Jun 04, 2018 1:33 pm    Post subject: Reply with quote
D.html
To be honest the holes are so insignificant that I don't mind them whatsoever. No one will be sitting in the back to see them Thumb
Magic919
PostPosted: Mon Jun 04, 2018 6:54 pm    Post subject: Reply with quote
Any parts bought from Porsche have a two year warranty. Nothing to do with the extended warranty you buy.
The engine probably suffered bore scoring.
997.2 C4S PDK
OllyW
PostPosted: Fri Jun 08, 2018 9:52 am    Post subject: Reply with quote
I'm wanting to increase the front camber a fair bit. Any advice? Best way to do it?
I'm in a different world to what I'm used to. With the MINIs, £250 gets you a pair of decent adjustable top mounts but that's not looking like it's the case here!
weebz
PostPosted: Fri Jun 08, 2018 12:15 pm    Post subject: Reply with quote
RSS has a whole suite of adjustable suspension components available.
May be worth give Centre of Gravity a call to discuss options or available parts.
MaxA
PostPosted: Fri Jun 08, 2018 12:36 pm    Post subject: Reply with quote
You can add camber plates or lower arms to change camber, but the former tend to be fixed and the latter, very expensive...
I ordered fully adjustable camber plates from Vorshlag at around $400+ but they didn't fit the H&R lowering springs (I don't know why just now, something is off with either my ability to order or the supply). It shouldn't be impossible ...
ninenineseven
PostPosted: Fri Jun 08, 2018 12:42 pm    Post subject: Reply with quote
I'm looking into this myself at the moment, cheapest i've found so far is Tarret but they're not adjustable they just give you -1.1 degrees of extra camber.
https://www.design911.co.uk/fu/prod130393/Front-Monoball-Shock-Mount---Set-Of-2-for-Porsche-996---997---986---987----TARETT/
Elephant Racing have camber adjustable mounts but quite expensive IMO.
https://www.design911.co.uk/fu/prod137720/QuickChange-camber-plates-Porsche--996-997-C2---986---987/
I really like the look of Ground Control which are camber/caster adjustable but there doesn't seem to be a UK distributor - it also looks like they will custom make them to suit the ID of the BC springs.
https://groundcontrolstore.com/collections/997-camber-plates/products/porsche-997-camber-plate?variant=36678097731
OllyW
PostPosted: Fri Jun 08, 2018 2:13 pm    Post subject: Reply with quote
The Ground Control camber plates don't look badly priced actually. But why it doesn't mention the range of available camber, I don't know.
Anyone know the answer? I'm wanting at least -2.5 so I can get the car set up for fast road/track and have no rubbing of tyres.
MaxA
PostPosted: Mon Jul 02, 2018 7:32 am    Post subject: Reply with quote
I saw these adjustable lower arms from Eibach (up to 2 degrees of camber) in the design911 webshop, but haven't looked for any reviews yet. Really need to spend some more time on the US sites like rennlist.
https://www.design911.co.uk/fu/prod136142/Adjustable-Lower-Control-Arm-Kit-for-Porsche---EIBACH/
£525 before discount.
crash7
PostPosted: Mon Jul 02, 2018 10:10 am    Post subject: Reply with quote
Olly, in the world of Porsche unfortunately there are limited options and none are cheap!
You can dial in a little camber on the standard top mounts, the mounting holes in the strut top are slotted, if your lucky you may get to neg 1.5 dependent on ride height etc - The down side being that by moving the strut top inboard to increase camber you lose track width.
Adjustable, two piece, lower control arms are the way the factory adjust camber, these are fitted to GT/Cup cars and available from Porsche.
Adjustable top mounts with the sliding adjustment are not commonplace, GT3 monoball top mounts have a motorsport mounting position which allows the damper to be mounted as outboard as possible to increase trackwidth while providing the maximum camber.
If your looking for circa neg 2-2.5, I would go for Porsche/Adjustable LCA's. - These with around 7mm of shim coupled with the slots in the strut mount should get you where you want to be. - From memory a pair from Porsche were around £1k, I believe the RSS items to be about the same.
Off-Topic, great rims, BBS E are immense!
MaxA
PostPosted: Mon Jul 02, 2018 11:02 am    Post subject: Reply with quote
Agreed. As far as I can make out, you can get top mounts from Taret, Elephant, Vorshlag and Ground Control, all around $450-500. And the OEM GT3 as well. Don't know what they cost. Almost afraid to ask.
As to LCAs, I think the choices are OEM (GT3), RSS, and Eibach, with the latter about one half or one third of the others in terms of cost. They look easy to adjust but I was still looking for anyone with any experience of the Eibachs before I pull the trigger.
I have about 1.3 degrees of camber at the front (which helps in the corners), but I do need to space them out again as they look pretty tucked.
Jamie_c
PostPosted: Tue Jul 03, 2018 6:29 pm    Post subject: Reply with quote
I've finally pulled the trigger on a set of those seats! What did you do with regards to the airbag light? Code it out, add a resistor or just ignore the light?
OllyW
PostPosted: Wed Jul 04, 2018 9:43 am    Post subject: Reply with quote
I've just been ignoring it. It would be nice for it to be gone but it doesn't bother me too much, seeing as I know the reason it's there.
Which did you go for? The leather or Alcantara?
Goto page Previous  1, 2, 3, 4, 5  Next
Page 2 of 5
