Slippydiff
- Joined
- 22 Nov 2007
- Messages
- 867
Apologies for the poor picture quality.
Removed off my Mk1 996 GT3 Clubsport. They will NOT fit C4/C4S, they WILL however fit a a standard 996 C2 :
https://rennlist.com/forums/996-forum/462218-installed-gt3-suspension-on-996-c2.html
You'll need either OE Mk1 996 GT3 anti-rollbar drop links, or you can buy the components off the shelf and have some adjustable jobs that will enable you to set the corner weights without any ARB preload at static ride heights. Knowing the price of the OE items, I'd buy the necessary components and assemble my own (no mechanical skills needed) the parts can be bought for less than £100 all in.
Or... if you're patient you'll find a thread on the PH Porsche forum that tells you which other mainstream (non-Porsche) cars use exactly the same droplinks as the Mk1 996 GT3 and they can be bought from Euro car Parts for less than £30 each (but they won't be adjustable)
You'll also need 996 GT3 top mounts or the equivalent from Tarrett, Elephant racing etc. These aren't cheap (so the damper kit IS :mrgreen though they do appear on ebay, on here and Rennlist occasionally
£175 Collection only.
