996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
M2SHD
PostPosted: Sat May 19, 2018 4:39 pm    Post subject: 997.2 Carrera S PDK - new engine bay leak Reply with quote
Ok friends, looking for some thoughts please. New oil leak noticed, see photos.
Reported to dealer, they’ve recommended not using the car and it’ll be getting collected by Porsche Assist but they can’t take it for another three weeks. Not ideal now Summer is here. Only 1k miles since I bought it last August. Two year warranty so I’m strongly expecting this will be covered.
997.2 Carrera S, 2009, 37k miles, PDK.
I've circled in red where the oil appears to be coming through the casing.
2009 992 Gen 2 PDK Arctic Silver
2018 Macan Volcano Grey
 Filesize:  979.25 KB
 Viewed:  2277 Time(s)
 Filesize:  106.42 KB
 Filesize:  98.05 KB
PostPosted: Sat May 19, 2018 5:26 pm    Post subject: Reply with quote
Do Not start the car or drive it !
It may well be oil from higher up but the part that is covered in oil is the high pressure fuel pump .. ive not seen that before so im on the side of caution here .
I dont actually think its oil .. i think its petrol .. can you smell it please .
It should well be covered by warrenty as thats not a small leak ... if it is petrol then its the pump and that would certainly be covered ...
It would also be bad to start the car with that leaking .. very bad .
M2SHD
PostPosted: Sat May 19, 2018 5:34 pm    Post subject: Reply with quote
Thanks for the quick response. It's not been started since I noticed the leak on Sunday. It wasn't there when I left the garage but I spotted it when putting the bike away later that evening.
I've been out and sniffed the oil off the casing. Odourless - not petrol.
PostPosted: Sat May 19, 2018 5:37 pm    Post subject: Reply with quote
Ok thats a relief , one of the pictures shows a clear ish fluid that looks like its evaporateing and combined with where the leak is i was a little concerned .
Anyways .. best not to start the car and just have it recovered .
If it helps all Porsche garages are snowed under atm .. its that time of year and due to the weather cars have been later comeing out of their winter sleep .
Cant move in our workshop atm .. sigh .
M2SHD
PostPosted: Sat May 19, 2018 5:45 pm    Post subject: Reply with quote
Did a quick Google on 997 High Pressure Fuel Pumps and it seems there was a recall. May be unrelated.
https://www.pistonheads.com/gassing/topic.asp?h=0&f=48&t=1025154
It's disappointing. When I took ownership on August 1st, I only had the car two weeks before it was taken back for two months due to a faulty tracker. Then it was Winter in Scotland until pretty much last month!
 Filesize:  210.82 KB
 Viewed:  2219 Time(s)
PostPosted: Sat May 19, 2018 5:59 pm    Post subject: Reply with quote
There was a huge recall on these pumps ( ive done countless replacements at OPC ) ..
It effected every model so Cayenne , Boxster 997 etc etc.
It wasnt for leaks though Smile
DFI pump operates at very high pressures .. if a pipe fractured then the small jet of fuel could cut through steel .. hence ny concern !
Weather has been strange this year .. all the garages i know were late to pick up work .. its quiet in the winter and snowed under in the summer for Porsche garages but this year has been late picking up .
M2SHD
PostPosted: Tue May 29, 2018 10:00 pm    Post subject: Reply with quote
It's away. Will keep the thread updated as and when I hear anything.
 Filesize:  130.2 KB
 Viewed:  1877 Time(s)
PostPosted: Tue May 29, 2018 10:04 pm    Post subject: Reply with quote
Woah Surprised
Them Dyson's can pick up anything nowadays Sad
Swampy
PostPosted: Wed May 30, 2018 8:54 am    Post subject: Reply with quote
Hoping that your not off the road for long M2SHD, please keep us updated !
Swamped By Swampy Smile
M2SHD
PostPosted: Thu Jun 07, 2018 8:06 pm    Post subject: Reply with quote
OK, so good news from Porsche:
"Your 911 has been diagnosed as a leaking High pressure fuel pump. This is operated through the camshaft rotation and has an oil feed where it is leaking from.
This repair is covered under warranty. The parts will arrive tomorrow."
And the response after I asked about the recalls on 997.2 fuel pumps:
"Yes the pump is going to be replaced.
I am not sure if you car was applicable but you will be receiving the latest level fuel pump."
Respect to deMort for the spot-on initial analysis!
Alfaian
PostPosted: Thu Jun 07, 2018 8:17 pm    Post subject: Reply with quote
What a result mate and dofs cap to demort worship
Btw, the car looks fab even on a tow truck so, get out there and enjoy it Thumb
Arctic silver C2S
M2SHD
PostPosted: Thu Jun 21, 2018 7:24 pm    Post subject: Reply with quote
OK, so the car is back. I've been informed a new High Pressure Fuel Pump has been installed. I've included a photo below where you can see a new part in there.
All appears well but I've noticed the near side exhaust pipes are now 1cm lower and protruding by the same amount. Once you notice it, it's a pain. I need to decide on taking it back to get it refitted properly. It's been away too much already and I don't want to miss any more of the Summer. Also, the medium to longer term plan is to fit a new sports exhaust system anyway.
Thoughts?
 Filesize:  115.08 KB
 Viewed:  1160 Time(s)
 Filesize:  262.26 KB
arifg
PostPosted: Thu Jun 21, 2018 7:32 pm    Post subject: Reply with quote
Mine failed a few weeks ago; the car has done about 22000 miles. 09.
Was replaced under warranty.
Did not notice a leak, but reduced engine power and then a message to take it to the workshop.
Black 2011 Porsche 997.2 Turbo
Black 2009 Audi R8 V8
Black 2016 BMW X5 3.0 L
PostPosted: Fri Jun 22, 2018 6:23 pm    Post subject: Reply with quote
Rather strange the mechanic removed the tail pipe .. you dont need to at least i never have and ive done one or two shall we say .
Perhaps there was a problem with corroded bolts Dont know
The usual failure of these it a warning and a very sick car .. if you look at the pressures on a tester then for us mechanics it gets scary as you see them going higher and higher .. i still remember the first one me and another mechanic were looking at and as we saw what the pressures were getting to we both shouted Turn it OFF as the same time lol .
Anyways i digress .. i was concerned it was a fuel leak which would be very bad but fuel or oil its a new fault to me and not as above and how they normally fail .
Btw if it has been off then its a waiting job to have it realigned , its only a pain when it hasent been removed in years .
Magic919
PostPosted: Sat Jun 23, 2018 11:04 am    Post subject: Reply with quote
I wouldn’t bother going back specifically for the exhaust, especially if you plan to fit PSE.
997.2 C2S PDK
997.2 C4S PDK
